Lift and Tire Advice while Towing a Boat or Trailer
Old Jan 16, 2014 | 08:36 PM
TripleThreat's Avatar
Default Lift and Tire Advice while Towing a Boat or Trailer
Background...
I have a 2000 Disco II...
ACE Package (Flushed with New Filter)
SLS (with new bags)
Slotted Rotors (Front and Rear)
New Front Calipers
New Brake Pads (Front and Rear)
New Upper and Lower Ball Joints
New Track Rod
New Drag Link
Front Drive Shaft Rebuilt and Serviceable
All Differentials have new Synthetic Fluid
All Door Lock Actuators Replaced
Hard Labor Creek Fabrications Winch Front Bumper
Hella Driving Lights
New GPR 4.0 Engine (Top Hat Sleeves, ARB Head Studs, Teflon Water Jacket Lining, Cam)
18" Wheels from a 2004
I will be installing a 2004 Shifter to be able to engage my CDL in the next couple of weeks (I have all of the parts, just need to find time).
I hope to install a roof rack and ladder at some point in the future, and may decide at some point to install a Hard Labor Creek Rear Bumper and Spare Tire Carrier and a Winch.
My next modification is to invest in a 2" Lift and some larger tires. Which is what led to this post...
I will likely go with an OME 2" Lift and 2" Spacers for the rear SLS - Hard Core Off Roaders will scoff at the idea of keeping the SLS and ACE, but based on how I use the Disco, I am going to keep them.
It is a daily driver in the winter when the weather is bad and it is driven in the summer when I pull our 21' MasterCraft ski boat, or an enclosed 18' all aluminum motorcycle trailer, or when I feel like exploring some back country unimproved roads, or to seek out a camping spot. I also will hit some of the less challenging trails at a couple of local off road parks.
Since I use the Disco to pull trailers, I don't want to go with too tall of a sidewall that might induce a bunch of squirminess when towing, but I would like to fill the wheel wells a bit more and have a more aggressive tire for those occasions when I am off road, or during some of the nasty snow we get in the winter. For those reasons, I think I want to stick with an 18" wheel.
The towing is where the ACE and the SLS really make a huge difference in how level it sits and how it pulls, which is why I don't want to get rid of them.
I'm currently thinking that I might opt for the following size tires:
265/65/18
275/65/18
or
265/70/18
275/70/18
I definitely do not want to cut sheet metal, as this is a daily driver, not a dedicated trail vehicle.
I'm interested in any experience anyone has with a 2" lift and this size tires. Especially if you ever tow anything with your Disco.
If you have pictures, post them up...
Old Jan 16, 2014 | 08:47 PM
dusty1's Avatar
I have trailered with 32" tires and a 2" lift.. No problems at all and it was heavy work trailers. 32 an 2 look great in there plus keeping the bags is a big bonus for the towing. I towed with and without... Much more squat after
I still have the tires in the garage I will look in the morning to see what size exactly
Old Jan 16, 2014 | 10:24 PM
Charlie_V's Avatar
I'm sorry to be so dumb but on the 2 inch spacers are you referring to wheel or coil?
I have a 3 inch terrafirma lift, which I am told is the same amount of lift as a 2" OME. I also have 2 inch wheel spacers (Bora) and what amounts to 33x10.5x16 Toyo M/T tires (I believe they are 285/65/16 but I am more sure of the inch measurements) and they rub the plastic well liner when I turn and hit a bump. My measurements showed that 1 inch less tire diameter or less wheel well would be perfect and produce no rubbing. That's pretty close to your setup.
Unfortunately I have a bare bones suspension and my Disco squats like a duck when I hook up a heavy (5000 pound) trailer, but does fine with a 1500 pound utility trailer loaded with about a ton.
By the way, NICE specs on your rover.
Old Jan 17, 2014 | 04:34 AM
antichrist's Avatar
I've been towing for decades on 7.50R16 without any problems. They are about 32"OD.
Old Jan 17, 2014 | 07:28 AM
Charlie_V, my Rover is equipped with SLS (Self Leveling Suspension) in the rear, rather than coils. As a result of wanting to keep the SLS for the purposes of towing, they make 2" Spacers that go under the SLS Air Bags which create the lift. You can actually just change the height of the rear by pumping more air into the bags by adjusting the electronic height adjustment switches, but that ultimately makes the ride more harsh and also reduces the available travel in the bag, so the spacers tend to minimize those compromises.
Thanks for the compliments on the Disco... I've spent way too much money on it, but I've done all the work myself, including a repaint from the rear quarter panels forward after a brain fart involving a steel post in a parking lot a couple of years ago.
Hopefully that clarifies the issue with the spacers for you...
Old Jan 17, 2014 | 08:08 AM
coors's Avatar
I've only towed once, see attached. Honestly, I couldn't imagine pulling that trailer w/ the 265/75's I have now. At the time of the pull I was running T.F. MD coils and 255 stockers. It struggled uphill (engine was tuned-up and running like a top).
Old Jan 17, 2014 | 08:13 AM
dusty1's Avatar
^^ good point. towing in hills and elevation, I'd be a wanting some gears.
coors's Avatar
Here's w/ TF MD kit and 265/75 BFG T/A KO's.
Here's the TF MD kit w/ stock 255's Geolanders (shot right after lift install, so no suspension settling has occurred yet). It looks silly
Old Jan 17, 2014 | 08:30 AM
acamato's Avatar
I have a DII (SLS and ACE) with a 2" TF med lift w/ SLS spacers.
Here is a thread with photos: https://landroverforums.com/forum/di...t-tires-61751/
I have 255/70R18 tires. They are 32.1" in diameter same as 275/65R18. The only difference is about 1" in width.
I haven't towed anything yet.
Old Jan 17, 2014 | 08:34 AM
Charlie_V's Avatar
It does. Sorry for my confusion. I live far from the closest dealer and everyone thinks my Disco II, which I've had since 2000, is an exotic car, so I don't see many others. SLS sounds like a nice feature for towing.
