Lifted
X2 for tires being balanced. That is most likely what it is.
I have always been told by various people to get an alignment after you install a lift, both by the dealer and other rover owners. Not sure if there was truth to it. but yeah, it must be the combination of the stabilizer and tires being balanced. My truck vibrated pretty bad, i had to get my tires balanced 3 times. They just wouldn't do it right.
on
JYC, I'd like to see the instructions if you can send them - gilder@bellsouth.net - much appreciated.
CDL instructions sent ... let me know what you think.
CDL instructions
jycsalas,
Could I get you to send me the CDL instructions? I was off-roading in my DII and the tire spin was killing me out here in SoCal. A CDL would have completely prevented that. I am looking to install a used shifter with the CDL link onto my currrent rig. Going to do something very, very similar to what was completed by gilder. By the way, that truck looks awful nice Gilder!
email to jonsocal at yahoo dot com
Thanks!
John
Thanks!
John
Ok, the new steering stabilizer arrived this afternoon and made a huge difference, but there is still a slight steering wheel shimmy between 60 and 68. I'm going back and have them re-balance the tires and hand-torque - had to use a cheater bar to get the nuts off when I was swapping tires around. That really chaps my *** .....
Thanks JYC for the CDL info - I will definitely put that on the project list. And, thanks to the rest of you who replied. I'll update after the re-balancing act....
I have a 3inch lift on my 98, I went through all kinds of stuff trying to locate each shake, shimmy, and vibration. In the end a set of matching Rover Tyme raduis arms corrected everything. When you lift your truck it raises the pinion angle slightly, that in turn will cause a slight vibration from your front driveshaft. The vibration can be noticable at different speeds.
KevinJec21
05-02-2007 08:23 PM
