Light Bulb seat?
Old Nov 22, 2009 | 11:58 AM
RoverRookie's Avatar
Default Light Bulb seat?
Had my right front turn signal stop working so I went to chande it. When I took the orange cover off it was filled with water...not good. I removed the turn signal bulb but I'm pretty sure I should replace the seat it was in due to the water. What is the seat called and how does it come off and finally WHERE do I get one? Thanks all - RR.
Old Nov 22, 2009 | 12:50 PM
meltdowndave's Avatar
What caused the water to get to it?
If you replace it without fixing the root cause you'll be doing it again.
Also, what's the year for your Disco?
In the meantime, try www.roverlandparts.com for used stuff.
Cheers.
Old Nov 22, 2009 | 01:49 PM
Dave, I don't know. Apparently the part I was asking about is referred to as a pigstail? Anywho, the Beast was born back in 1999. Thanks for the response. RR.
Classklown90
Aug 21, 2010 07:24 PM
mcbenavidez
Nov 24, 2007 05:47 PM
jcw
Dec 3, 2005 02:21 PM
Claree
Freelander
Nov 8, 2005 11:12 PM
AzCamel
Jun 14, 2005 08:39 PM
