The light trio - with a twist
Old Mar 5, 2007 | 07:24 PM
Aquaholic's Avatar
Default The light trio - with a twist
Last week I changed the rear brakes - yes I opened the bleeding valves before compressing the pistons.
Saturday I was pulling into a parking lot when the Rover (03 SE 41,000 miles) beeped and the TC, ABS, and BRAKE lights illuminated. I turned the truck off and when I re-started the lights did not return.
Sunday I did the front brakes. Changed the fluid to synthetic and bled the system twice.
Any thoughts? What should I tell the dealer when I bring it to them next (since it's under warranty)?
Old Mar 5, 2007 | 08:43 PM
shagybruce's Avatar
Default RE: The light trio - with a twist
happened to me last week as well although i hadn't done anything to the brakes. they came on twice and after shutting off the engine they stayed off. touch wood havent been on since..mine is a 2003 se as well. although my wife did drive through some water before it happened. may have something to do with it.
Old Mar 6, 2007 | 10:06 AM
Did you use factory pads? Don't tell the dealer you used syntheic fluid or the will blame your problems on that.
There is a good chance you just have a loose wheel sensor that may need to be pushed back into it's proper position.
Mike
Old Mar 6, 2007 | 02:07 PM
Aquaholic's Avatar
I used Mintex Red low dust pads.
Thanks for the advice.
Old Mar 6, 2007 | 06:55 PM
Elhoff's Avatar
My '99 did that once also. It was after an 8 hr drive including a traverse of the Sierras. Lights came on at a stop light. I shut it down, restarted, and no more lights. All seemed well. Unfortunately for me, there was actually more to come. It took about 2 months for them to come back on and stay on. This time I replaced all the brake pads (Kevlar back to stock, I have DBA slotted rotors), then had the code read (variable output from ABS sensor) and cleared. No sign of the lights for the past 6 months.
xb70valkarye
Sep 2, 2008 08:43 AM
Disco Doc
Jan 10, 2008 01:17 PM
Dublz
Sep 4, 2007 08:31 AM
charcoal grey
Jun 30, 2007 01:15 AM
esaycho
Dec 12, 2006 09:44 PM
