In-line fuel filter?
Old Sep 2, 2012 | 07:52 PM
bwilliam's Avatar
Default In-line fuel filter?
Greetings -- Just wondering if anyone has previously modified their rig with an in-line fuel filter? I'm going to be replacing the fuel injectors next week and it seems to me like it might be a good precaution against any residual dirt or rust in the gas tank clogging the injectors.
Old Sep 2, 2012 | 08:13 PM
lr2001silver's Avatar
Banned
Why are you replacing your injectors?
Old Sep 2, 2012 | 08:23 PM
bwilliam's Avatar
Well, kind of a long story, but the readers digest version is this: check engine light has been on and I had it in to the dealer to diagnose. They did a smoke test and found air leaking around injector seals and recommended having injectors ultrasonically cleaned at the same time. This makes sense to me although Im doing the work myself and sent out a spare set of injectors for cleaning.
Old Sep 2, 2012 | 08:52 PM
You do not want to replace the injectors, D2 injectors rarely go bad and it is not uncommon to have a dealer say that just for the extra $$$$$$.
What fault codes do you have and how many miles on the engine?
Old Sep 2, 2012 | 08:58 PM
bwilliam's Avatar
Fault codes are lean-running (p0171, p0174) and also misfire (p0300). Mileage is 130k. I guess I could just replace the injector o-rings, but if that doesn't fix it, it just means taking it apart again.
Old Sep 2, 2012 | 09:38 PM
Sure you could add a fuel filter but why?
You have not had any problems this far right?
Old Sep 2, 2012 | 09:50 PM
bwilliam's Avatar
Well, I guess the concern is clogged injectors. Local guy I talked to that does ultrasonic injector cleaning says he sees a lot of Rovers. Here's the dealer diagnosis if that helps shed any light on it...
Old Sep 2, 2012 | 09:57 PM
bwilliam's Avatar
I recently did a head gasket job, by the way, so all the other seals should be good.
Old Sep 2, 2012 | 10:00 PM
There is already a fuel filter in the gas tank.
I have yet to hear of any Rover injectors going bad, but that does not mean it does not happen.
Mine are original, I've never done anything other than the occasional bottle of injector cleaner.
The DI does have a in-line fuel filter though.
But again I have yet to hear of any Rover injectors going bad.
Old Sep 3, 2012 | 12:37 AM
Banned
X two the injectors don't usually fail and are expensive. Your sock filter in The tank is all you need.
