link for building CDL linkage?
Old Oct 1, 2008 | 11:54 AM
suntattoo80's Avatar
Default link for building CDL linkage?
anyone got it i serched for it but cant find it
Old Oct 1, 2008 | 12:20 PM
Urban Panzer's Avatar
Default RE: link for building CDL linkage?
http://www.rovershoppe.com/cdl_handle.html
Old Oct 1, 2008 | 02:17 PM
Switzer's Avatar
Panzer beat me to it. It took me about an hour using a 1x36 inch flat sheet of aluminum from Home Depot. Just file the hole away until it fits snugly on the CDL nipple.
Cheers,
Pete
Old Oct 1, 2008 | 11:36 PM
Willie 00D2's Avatar
I built one of these for my 2000. They work good. Pretty smoothoperating.Not as nice as a 04 lever but for free I am not complaining.
Willie
Old Oct 1, 2008 | 11:44 PM
Switzer's Avatar
It is a slight inconvenience to get out and lock the T-case, but it means I can check my tires and everything else before hitting a trail. I lock it together whenever I hit dirt roads and speed below 40 mph.
Cheers,
Pete
Old Oct 2, 2008 | 04:49 AM
detcord's Avatar
ORIGINAL: Switzer
Cheers,
Pete
doesnt seem like aluminum would be strong enough for this....wouldnt it just bend when u try to use it?
Old Oct 2, 2008 | 07:42 AM
Pound for pound aluminum is stronger than steel.
Old Oct 2, 2008 | 12:16 PM
Disco2Guy's Avatar
[quote]ORIGINAL: detcord
[/quote
All it's doing to turning the nipple on the t-case about 45*. If you have a 10mm wrench you can turn it yourself to get an idea of the amount of force needed. Just do it when the truck is cool or you'll more than likely burn your arm.
Old Oct 2, 2008 | 02:36 PM
Switzer's Avatar
I chose aluminum because I saw it and it looked like it would work for my application. It is about 1/4 inch thick and only bends under a good amount of pressure, more than what is needed to engage the lock. Steel would work, but it may take longer to file the hole to fit the nipple.
Cheers,
Pete
Old Oct 2, 2008 | 03:19 PM
and it rusts !!!.......................................mind you that fits perfectly with Land Rovers then
