Locked Out
Locked Out
After sitting for a while I went to start my D2 but the battery was dead. I popped the hood and put the charger on it and then locked the doors and let it charge for the night. The next day the charge said it was charged so I took the charger off and shut the hood. I got the keys and pressed the unlock button on the remote but nothing happened. The red light on the remote lights up but nothing responds. I tried to put the key in the door but I can't get it in all the way. I sprayed it with penetrating oil and let it soak and tried again but still couldn't get it. It is currently soaking with the 3 spray of oil. I need to get into it to clean up a water leak before it gets full of mold or ruins my brand new headliner. Any advice would be appreciated.
The other key has the FOB broken, only the key part of it works which doesn't do any good because the key doesn't seem like it is going into the door all the way. I pushed it in as far as I could and it barely moves left and right. I am not sure how far the key is supposed to go in because I have never used it. Also, how do you change the battery in the FOB?
I tried the remote and the vehicle does not respond at all. Does anyone have any directions to replace the battery? I am assuming that the local auto parts store will have the battery but I need to get it out to see what size it is.
The battery was dead in the vehicle so that is probably the cause. I sprayed the crap out of it with penetrating oil with no luck. It seems like the key is not going in all the way but that might just be how Land Rover's are. I also tried the old coat hanger through the door trick but couldn't get enough leverage on the lock to pull it up.
