Locker / Axles
Old Mar 12, 2013 | 11:06 AM
05gixxer's Avatar
Default Locker / Axles
As my rover ages I find myself pretty much using it only as a trail vehicle. This year I would like to improve the capabilities by purchasing a locker for the rear axle.
I am looking at the Tru Trac or a Detroit full time locker. I know if I go with the Detroit I will need a set of ashcroft axles to go with it.
If I go with the Tru Trac will the stock axles hold up and will it really improve my traction?
I would rather spend the money on the detroit and axles and know that this will greatly improve the capabilities than to buy a Tru Trac and never really have it fully lock up on off camber situations.
Has anyone had any experience with a Tru Trac in the rear axle and did it really help?
I mostly wheel in hard pack areas with alot of big rocks and hills I at all cost avoid the mud as I hate all the clean up involved.
Old Mar 12, 2013 | 11:22 AM
I have a number of friends here in Colorado that run T.T.'s front and rear and swear by them.
I run a Detroit in the rear and t.t. in the front, which works well for me.
What sort of wheeling are you doing to need a locker? Don't put the T.T. down it is a really strong locker and along with a CDL handles itself well off road.
Old Mar 12, 2013 | 11:35 AM
05gixxer's Avatar
I have the Cdl done but all my buddies run jeeps with welded rear diffs and there has been on a couple occasions I couldn't make it up some of the hills they do because of the off camber situations.
What do you think about a T.T with stock axles? what is likely to go first the ring and pinion or an axle I really have no idea how strong the axles in these rovers cause I have always babied it because of the weak pin in the diffs.
Most of terrain are long hills with twist and turns and usually a steep ledge at the top.
Old Mar 12, 2013 | 01:11 PM
kfx4001442's Avatar
Tire size is gonna be a big role in this equasion. If your running the tires listed in your signature, those aren't that big. I think they would hold up pretty well as long as you don't raw dawg it.
Old Mar 12, 2013 | 02:26 PM
ZGPhoto's Avatar
33" tires are still quite a bit larger than stock, and carry quite a bit of rotational mass.
CUpgt
Jul 5, 2013 04:57 PM
fishEH
Mar 6, 2013 09:43 AM
dinandan
Jun 6, 2006 09:26 AM
takar12
Jan 6, 2006 10:38 AM
Hobes
Jun 28, 2005 02:46 PM
