Lookin to lift
Old Nov 28, 2009 | 11:42 PM
Ecoe Blazin's Avatar
4th Gear
Question Lookin to lift
hey i was thinking about putting a 2" lift on my 03 Disco SE and i was wondering how the lift affects the top-heaviness/rollability. im a noob, but just curious. would it be necessary or wise to widen the wheel base?
thanks for the help
Old Nov 29, 2009 | 12:28 AM
NiteTrain's Avatar
yeah it'll raise the COG (center of gravity) some...just avoid high speed maneuvers..as you always should with a disco. You can widen the wheel base with wheel spacers but I wouldn't advise doing that.
Old Nov 29, 2009 | 07:40 AM
gilder's Avatar
Do you want this lift for "show" or "go?" In other words, are you going to off-road with it?
Old Nov 29, 2009 | 07:46 AM
hilltoppersx's Avatar
don't widen the wheel base. don't make sharp turns at 20+mph and you wont roll with or without a lift.
Old Nov 29, 2009 | 11:55 AM
AK Rover's Avatar
Go with HD springs and shocks and you won't even notice the change in center of gravity. If anything my truck felt more stable after the lift than on the stock springs.
Old Nov 29, 2009 | 07:20 PM
4th Gear
aight thanks fellas. hell yeah im goin offroad with it!
Old Nov 29, 2009 | 10:40 PM
gilder's Avatar
Whether the 2 or 3 inch lift you will be ok as far as stability goes as long as you keep your front and rear sway bars attached. If you disconnect them you will of course have issues on the road - hence the quick disconnect kits available from several manufacturers. I went with RTE's HD 2 inch lift - I'm sure the OME is similar. Either is good - I'd steer clear of anything else. Enjoy!
Old Nov 30, 2009 | 10:13 AM
You know you don't have a CDL or locked diffs so your wheeling is limited.
I would suggest you get your front drive shaft rebuilt first, before it breaks and takes out your tranny, then look at some sliders and some diff guards. That along with some good tire, a lift and eventially a CDL and lockers, then you will be ready for some of those trails you have in your state.
Old Jan 16, 2019 | 07:55 AM
CollieRover's Avatar
thanks for the help
I had a medium OME lift, and it handled much better with the stiffer springs.
Old Jan 16, 2019 | 08:39 AM
Saturnine's Avatar
This is from like 10 years ago
