Looking for Advice on P1172 and P1175 Codes
Old Jul 9, 2016 | 09:27 PM
discorey's Avatar
I may also pull the intake apart so I can clean it and check the injector seals.
Old Jul 9, 2016 | 09:40 PM
disc oh no's Avatar
Injector seals would make it run lean, so that's probably not an issue.
What is the TPS reading at idle?
You could try cleaning the throttle plate. Sometimes if you get enough carbon build up in there it can stick the throttle open a little bit. The computer sees an open throttle from the TPS and starts adding fuel, but it's actually closed against the deposits. You may have to remove it and really clean both sides good.
Old Jul 9, 2016 | 10:02 PM
discorey's Avatar
I just checked the throttle plate only finding a little oil residue, but no buildup or varnish.
I will let you know what the readings are after cranking it back up.
Do you think it's okay to crank it without the flywheel grommet?
Old Jul 9, 2016 | 10:25 PM
disc oh no's Avatar
As long as there's nothing in the way of the flywheel, I don't see why not.
Old Jul 9, 2016 | 11:14 PM
discorey's Avatar
Here are my readings:
intake temp: 76f start 96.8f after 10 mins
fuel trim: -1.6 - 0 at idle, both sides
maf: 6.1
vac: -10
o2: .1 and jumps to .8
coolant temp: 76f at start, 194f after 10 mins.
Old Jul 9, 2016 | 11:17 PM
discorey's Avatar
There's something up with the extra nipple below the oil separator line on the plenum.
When I plug it, she idles sort of normal. When I remove the plug she starts bogging down and will stall if I don't hit the throttle.
Old Jul 10, 2016 | 09:17 AM
disc oh no's Avatar
maf: 6.1
vac: -10
Which fuel trim reading is that? Check the long term and short term fuel trims. They should both be within +/- 10%. Anything over that and there is a problem.
On the MAF sensor reading, try doing a couple snap throttle tests. Open the throttle all the way and quickly release. The reading should spike briefly.
Old Jul 10, 2016 | 09:20 AM
disc oh no's Avatar
I'm not sure exactly what this is. Is it missing a plug, or a vacuum line?
Old Jul 10, 2016 | 09:33 AM
discorey's Avatar
There's a small nipple below the oil separator line and the vacuum line with the red quick release on the top passenger side of the plenum.
It's been like that since I bought it. I made a plug out of electric tape to seal it. I've asked on forums before what it goes to, and no one knows. It's a 99 model D2.
Old Jul 10, 2016 | 09:41 AM
disc oh no's Avatar
I don't know if mine has that. The '99 is different from mine, I think.
