Looking to buy a 00 D2
Hey guys, have been reading for a while and decided to join. I have read all the stickies and am looking to a buy a 00 Discovery II as the title states. It is used with about 90k miles. I will be the third owner and current owner does not know if driveshafts or headgaskets were ever changed(he did not do it and does not know if first owner did).
I have no garage or tools and am located in NYC, is it worth getting the headgasket replaced even if I do not have any problems? From what I read, the headgasket and driveshafts will go out no matter what?
Also is SLS standard with ACE? Which of those 2 have problems? I read SLS will have problems, some say ACE is good and I think I read some ACE problems?
Thanks!
Thanks!
Great thank you, I was going to assume no work was done and bring the car upto speed. I read the 60k and up major maintenance thread.
I read the rebuild thread and since I have no garage/tools/space and is this the correct item I would need my mechanic to install?
http://www.toddcosuspensions.com/larodiiifrdr.html
3 owners is not so bad. Any maintenance records from the last owner? Have your drove it? Any weird sounds? Engine idle sounds, both cold and warm idles? Any major leaks? Funny smells? Squeaks, whistles? Remember these trucks are nothing more than british 4x4 v8 farm trucks with heated seats and a nice radio. Ask the owner the last maintenance he did on the truck other than an oil change. If he again says "I do not know". Walk away....he is hiding something and is trying to unload his problem...haha
Oh and your gonna need some tools if you buy one of these. And that's for any 10+ year old v8 4x4, not just a rover. X2 NiteTrain.
If your in NYC with all the weather you guys have had a 00 D2 would be pretty fun right now though....what other 4x4s you looking into it? Or is the disco your only focus?
Thanks for the replies, I will see and drive it this weekend. Sadly I won't offroad, will use it to commute, road trips and ski trips. We do get a lot of snow here so one reason I wanted it.
Hmm otherwise I would spend more and buy a new Xterra or used 4runner.
I can get the D2 without a car payment.
Just test drove it on highway, local streets and snow . Drives awesome! Drove it for about 20 miles almost, did not hear or feel anything weird at all!
Front drive shaft has not been done, owner has receipts for oil changes and fluids have been checked/topped off.
Does the front driveshaft go out no matter what? This is the only thing I am worried about... It has 95k miles, no noises, squeaks or leaks at all. Drives like a dream in snow as well! Interior was perfect with no tears or rips, slight headliner sag.
I will probably change the plugs/wires/coolant and brakes feel like they are on the way out.
Also how do I know if it has ACE? It has leather(no heated seats), 18inch rims and hill descent control.
What do you guys think? I am going to buy it I think...
Good luck.
