Looking at a Disco tonight
Old Jul 26, 2007 | 05:16 PM
Wizaugh's Avatar
4th Gear
Default Looking at a Disco tonight
01 Disco IISD 107k miles for 5900 and the guy swears there's nothing wrong with it The price seems a little low to me, and it's at an auction lot so it's got me a little worried. What all should I look for besides the usual car buying stuff. Any common problems besides maybe an oil leak? I'm waiting for my buddy to get back to me with the Carfax...
BTW, great site here, lots of usefull info!
edit: Carfax came back.
52k colling system and brakes serviced
60k drive axle and engine serviced
64k suspension serviced
68k electrical serviced
74k tranny and engine serviced
Nothing reported after that. Looks like a rough 20k miles...
Old Jul 26, 2007 | 05:53 PM
98roverguy's Avatar
Default RE: Looking at a Disco tonight
Well, make sure you don't perform your critique of the vehicle in the darkness or even under good lighting. Daytime is a must. Take it for a test drive and test EVERYTHING including electronics and low/high range. Take your time on this. Ask for a service history. Check your fluid levels and colors of them. Make sure it has a smooth idle and does not make any strange noises or moans at speeds greater then 70mph or at any speed. Ya, take it on the highway and for a good drive. While at idle look over then engine for any whines and such. It will be difficult to immediatly find problems with a rover. They typically surface after about the first thoudand miles. Which is usually an expensive break-in period. But is typical of most buyers. And of course verify if it's been wrecked. There is a lot of electronic components to test so take your time. Be sure your crawl underneath it with a good flashlight and take a good look at everything. Let us know how it goes and welcome to theforum.
Old Jul 26, 2007 | 06:01 PM
98roverguy's Avatar
To bad the 90K wasn't done, those 30k, 60k and 90k's are important. I don't know if carfax reports those service intervals if they were done. Your gonna wanna hope they were. Also, most important, ask for extended or any sort of warranty information. At 107k its already time to service the tranny- past due... Be positive, but also realistic, there's alot of disco's in the sea. Best of luck and hope it works out for you.
Old Jul 26, 2007 | 06:38 PM
Price is about right when you consider the mileaage and that fact you will shortly put some money into it as a service.
Mike
Old Jul 27, 2007 | 08:06 AM
Wizaugh's Avatar
4th Gear
Well, dude said he was too busy last night, it will have to be tonight. That works though, gives me more time to research. Thanks for the help so far.
What are some of these probelems you refer to?
Old Jul 27, 2007 | 10:28 AM
98roverguy's Avatar
ORIGINAL: Wizaugh
It can be a pretty wide range. Based on your mileage I'd expect an initial heavy maintenance, such as all fluids being replaced, filters, plugs, wires, and eventually O2 sensors. It is really hard to say. Don't be intimidated though, I'm just mentioning what you'll want to do to it, not necessarily what will need to be done to it. You'll be fine. Let us know what you think of her and we'll all help you from there.
Old Jul 27, 2007 | 12:18 PM
Wizaugh's Avatar
4th Gear
One more question, then I'll stop bugging you guys
Who made the 4 liter used in these? The dealer said he was told it was the Olds motor, but that doesnt seem right...
Old Jul 27, 2007 | 12:21 PM
98roverguy's Avatar
It's an old Buick engine I believe.
Old Jul 27, 2007 | 01:34 PM
okdiscoguy's Avatar
ORIGINAL: 98roverguy
Yup Rover makes it, but bought the design from 60's model rocket 8 Buick. The D2's, even the 4.6 is modeled after it.
Old Jul 27, 2007 | 01:54 PM
Wizaugh's Avatar
4th Gear
ORIGINAL: okdiscoguy
I thought the 4.6 was the Ford motor from the Explorer/Stang?
