looking for used 4.6 engine options
After getting my D2 running perfectly something in the engine let go while going 75 on the interstate. No warning at all. Anyway it knocked the bottom out of the oil pan and took out a chuck of the block. I need some options for a used motor. hoping to stay under $1000. Ill be doing the swap myself. Ill replace the head gaskets and oil pump before the install as well. on a side note the lady behind me stopped and said it looked like something you see in a nascar race......smoke and flames coming out the back. I posted the carnage for your viewing pleasure......
Ill tear it down eventually and see.....I was seeing a slight misfire/running rough on #7 but nothing major and she ran very smooth of idle . Temp was 188 and no noise what so ever when it let go . Looks like it may have been piston 7 that did let go . Ill post it up when I know for sure what happened,.
What a bummer! Glad you are OK.
Look for a 4.6 out of a Range Rover. That seems to be the way to go, and hopefully it would be non-SAI. Not that there is anything wrong with SAI, you just would not have to deal with it.
Not sure how difficult they are to find though. Check eBay and Car-Part.com--Used Auto Parts Market
Also, make sure it is a Bosch motor. I just learned that RR's have GEMS as well, and had to return an alternator, but maybe all the 4.6's are Bosch, I don't know.
But if the heads are the same I imagine a GEMS would work, you'd just not use any of the ancillaries or top end past lower intake manifold.
If you are resigned to doing the HG's get a short block, and re-use your cylinder heads. You'll be able to inspect the bearings, etc. As long as the engine is out maybe upgrade the Cams to Crower or Kent. That would mean new new tappets, but you'd likely do that with a short block anyway. While you are waiting for the short block check and prep the heads changing the valve stem seals. Or ABran sells refurbed for a good price if you want to avoid shop charges and the work yourself.
Thx for the offer but thats too far for me.....hopefully I can find a suitable replacement local.
