loose drivers side seat,normal?
Old Apr 25, 2010 | 03:27 PM
bobco's Avatar
Default loose drivers side seat,normal?
i have a 2003 discovery and the drivers side seat rocks back on acceleration. Its been doing since i bought it new and the dealership has always said, its normal. Does anybody else have this happening? thanks for any help.
Old Apr 25, 2010 | 05:22 PM
lipadj46's Avatar
Mine did that ever since I got it then one day I leaned back to get a bag and the rear right corner collapsed. I removed the seat and cut out the welded on bolt and replaced it with a new bolt and now there is no more rocking. Not sure if it was that or if in the process of reinstalling the seat I tightened down whatever was loose but whatever it is nice to come to a stop and not have the seat rock.
Old Apr 25, 2010 | 05:34 PM
hilltoppersx's Avatar
no its not normal. its bolted to the floor its not designed as a rocking chair.
Old Apr 25, 2010 | 06:30 PM
hunter's Avatar
my 04 does it...don't remember if my 00 did. Slightly annoying, but livable.
Old Apr 25, 2010 | 06:56 PM
PhishPhan's Avatar
Default Same
my 01 Disco II does the same thing, try tighening the bolts
Old Apr 26, 2010 | 03:47 PM
Suede's Avatar
The best thing to do is to remove the seat from the vehicle and tighten the bolts that attach the base to the seat itself, then reinstall and tighten down the base to the floor.
Old Apr 26, 2010 | 05:53 PM
Antmen's Avatar
Check the four mounts/bushings where the seat connects to the rail. I haven't checked an LR, but some cars (like the BMW) have soft rubber bushings to absorb some vibrations. They wear or dry out. Replace them with same or harder plastic bushings.
-Anthony
Old Oct 13, 2017 | 10:51 AM
Armando's Avatar
I finally feel like I have something to contribute to this forum. I successfully fixed this on mine.
There is a metal tube that goes into a hole in the frame (visible from the outerside of the seat, nearest the door, after taking out the plastic trim).
It has a nylon bushing in it. This acts as a type of hinge that allows the seat to go up and down. With time, this bushing falls apart.
Ideally, you could take apart the seat and replace the bushing (it inserts from the inner part).
If you don't care to take apart the sear, you can insert material in there by pushing it in with a very small flat screwdriver. Insert it all the way around.
I was going crazy with the rocking back and forth so I used paper towel as a temporary repair. It's held up just fine for a week now, but as soon as it starts wobbling again (if it does), I will try to do with some type of nylon material.
I'll add a pic when I get a chance.
Old Oct 9, 2021 | 12:47 PM
brivalen's Avatar
old thread, pic? I've successfully driven myself nuts trying to fix this. I bought a used seat frame on ebay and it might be worse then my original one.
Old Oct 11, 2021 | 11:12 AM
thebilgerat's Avatar
Not normal on my rig - I'd check the bolts.
