Loose window???
Old May 3, 2007 | 12:43 AM
ZMayo85's Avatar
Default Loose window???
AfterI bought mydiscoI realized that the passenger side window lets air in. Itsnot the glass, but the black part of the upper door frame. Sometimes its not bad and then somtimes it sounds like its wide open when i'm driving down the highway. Is this something that could of happened because of a wreck or is there someway to tighten it?
Old May 3, 2007 | 12:15 PM
Default RE: Loose window???
So are you talking about the weather seal on the inside of the door jam leaking, have you looked at it to see if it is damaged or has a flat or torn spot?
Mike
Old May 3, 2007 | 01:09 PM
rphotographer's Avatar
you mean the metal black window channel? that the window slides in, not the rubber window gasket?
Old May 3, 2007 | 03:59 PM
ZMayo85's Avatar
yeah it seems like its the actual channel not the seal.
Old May 3, 2007 | 04:03 PM
bweaver's Avatar
I have the same thing on my drivers side. Thought the dealership messed it up, but maybe this is a wide spread issue.
Old May 3, 2007 | 04:22 PM
might try a glass repair shop, there might be w away to adjust the window.
Ralph
Old May 3, 2007 | 04:56 PM
okdiscoguy's Avatar
The regulators have a plasticwheel that runs in the channel. This wheel likes to break, and then the window doesn't quite go all the way up. Might pull your door panel and inspect the hardware. Mine broke and I had to glue it back and re-shape it. As far as I know, you can't just get the wheel, you have to buy the whole regulator..
Old Apr 9, 2008 | 03:57 PM
RossAngeles's Avatar
3rd Gear
What type of glue did you use to fix the wheel? This same issue just happened yesterday with my 2004 Disco on the Passenger Side and I tried Crazy Glue, but the wheel just snapped as soon as I rolled the window all the way back up.
Old Apr 9, 2008 | 04:02 PM
jmt's Avatar
jmt
A new regulator is like $80 from roverconnection.com
KlamathMatt
Jul 24, 2023 05:12 PM
twoxred
Oct 4, 2021 07:07 AM
jw928
Feb 6, 2010 06:51 PM
robot808
Nov 18, 2009 11:10 PM
