Losing Power on Steep UpHill
Hello all I am a fairly new Land Rover owner, I bought a 2001 Disco 2, V8 couple of months ago which I enjoy driving a lot now.
Recently I noticed on a steep hill the car loses power and just barely moves on I mean like walking speed, it does finish the hill. I never came to a full stop and even I did stopped fully it continues on the same way uphill, the max rpm is 1800 or so never goes more than that even full throttle. On normal hills I have no problem and on the highway as well no issue with power, even tried 160kmh/100mph without any issue.
What can be the issue I tried couple of times we have a very steep hill here and every time I lost power and just barely moved on, after the hill flattened car gets back underway.
Also, time to time on regular city roads, I encounter an increase in power when I reach around 2800-3000rpm. Until there the car acts a bit more stubborn to accelerate but then when it hits around 2800rpm it kicks you back.
Appreciate any ideas or any one that had similar issues.
Thank you.
Thank you.
Sounds like a transmission problem, try manually downshifting on the same hill. It would appear the transmission is not downshifting, which could be a few things so you are stuck in the drive and the rpm will keep dropping.
The other thing to try is to press the sport mode switch so the S lights up on a quiet stretch of road, while you are stopped, Then punch the throttle to the floor if all is right with the world you rev up through 4000 rpm then drop off as you ease off the throttle.
Also does your engine rev freely in neutral without hesitation
It could be other things but start there.
Yes I have no problem on reving on neutral, easy to rev. On idle sometimes the car like shivers but I aim to change the spark plugs, wires and coils at a point as well as I dont trust the previous owner.
When I put the throttle to the floor on S mode I can go over 5000 as well even though initial up to 3000 still feels a bit stubborn but not much at all. On straights its very good. The S mode also makes a difference on the behaviour of the car.
I tried the same hill on S mode as well no change it took a bit longer to slow yes but still it slowed down and the same thing happened. I also tried to downshift myself from D to 3-2-1 and nothing happened basically it stayed the same.
I dont have any problems on regular hills I can speed up and climb and so on or on straights but just at this very steep hill. I also tried low gear as well with a full stop in the middle of the hill but except the initial kick it also struggled.
One more note, if I start that climb in manual mode in 1st gear the car also struggles and gets stuck again around that 2000rpm level as well. The climb is very near to my house and I use that road time to time so I can try other combinations any time. The car never comes to a complete stop it just continues on with walking speed.
I think the 2 most common transmission issues are incorrect fluid level, and (believe it or not) low voltage. The transmission ECU seems to be very finicky with the voltage it needs. How is your alternator? And for fluid level, there are numerous threads here on how to check it properly.
I also tend to show it to a workshop that specializes on transmissions if I have the time.
appreciate your all comments thank you
