Lost Key (no replacement)
I lost my landrover keys and my dumb self did not make a spare key, so now im locked out. I can't drive my rover but have the FOB without the actual metal key, so i can access my rover only.
If anyone can provide me with helpful information i would greatly appreciate it.
I called landrover dealers already, they are all closed, they will give me a call back tomorrow Monday.
Can i order the actual key from the Dealer? What information would i need (ownership, insurace, VIN number etc.)?
Anyway i can put my car into neutral without the key? I dont think i can steer it since it will lock the steering wheel? Probably need a tow truck then???
THANKS
THANKS
+1. If you were in the UK they would want you to visit the main dealership with all the car docs, identity docs and probably inside leg measurement as well and then they might, just might, help you and charge you a kings ransom for the priviledge. Good luck.
A dealer in Denver gave me the key code over the phone with no verification of my identity or that I owned the car. There are only a few locksmiths left in the area that can cut from code but I did find a few. You may have the same luck calling the dealer. If your local dealer doesn't give it to you try the one in Denver.
In the meanwhile, you can always disconnect the electrical portion of the ignition switch from the mechanical portion.
When you remove the steering column shround you'll see it's the portion of the switch on the left end of the assembly with all the wiring coming off it. Picture #1 is of the complete assembly as you will see it in your truck attached to the steering column.
There are two very small (eyeglass size) screws that hold the electrical section of the switch to the main body of the assembly. Picture #2 shows the end you will be removing and one of the small screws facing you. The other with be on the exact opposite side.
With the screws removed, the round black portion will detach. This is the final picture #3 (actually of the part from a Range Rover Classic as it's what I had at my desk). With that done, you can insert a screw driver into the detent you can see, turn and the truck will start just like it would with a key.
