Lots of codes after major transmission work!! Help??
Old Oct 9, 2014 | 11:33 PM
cobbcj7's Avatar
Default Lots of codes after major transmission work!! Help??
I put everything back together after replacing a busted flex plate and it runs great! BUT I'm throwing codes everywhere now. I never unplugged anything from the engine to do this job.. So that's why these concern me a bit.. I am not driving it currently, but hope to soon so I need this diagnosed if possible
Also! I got all these codes, then cleared them to see if any came back, and they did..
Can you tell me if any of these are serious?? Googling them is not helping too much.. Thanks guys!
Attached Thumbnails Lots of codes after major transmission work!! Help??-screenshot_2014-10-10-00-23-21.jpg
Old Oct 10, 2014 | 05:39 AM
drowssap's Avatar
what kind of scanner are you using only 2 of those codes are LR, the othe rcodes must be propitiatory to your scanner
Old Oct 10, 2014 | 12:30 PM
cobbcj7's Avatar
I bought the code scanner that I have seen others refer to on here. The Torque Pro app for android and that bluetooth scanner..
Advanced ELM327 V1 5 Bluetooth Interface OBD2 Car Scanner Adapter Torque Android | eBay
https://play.google.com/store/apps/d...l.torque&hl=en
Old Oct 10, 2014 | 12:42 PM
MetalMarine's Avatar
sometimes when a code reader throws a bunch of codes.
it could be from a poor connection or a fault circuit grounding.
hopefully thats the issue.
you can also have autozone or another parts store scan for codes. its free.
Old Oct 10, 2014 | 12:50 PM
RicketyTick's Avatar
Looks like it may be set up for the wrong vehicle? maybe you should check it with another scanner then compare the codes with your scanner codes and see what you get....or if your scanner is right.
mdt9987
Mar 23, 2019 06:03 PM
pedro_malo
Jan 14, 2012 08:30 AM
bcolins
Oct 27, 2011 11:13 AM
aircraftguy
Jul 16, 2009 12:50 PM
SurfRat
Feb 12, 2009 08:33 AM
