Loud Roaring and Whining Noise
Old Jul 29, 2010 | 08:21 AM
jkistner's Avatar
4wd High
Default Loud Roaring and Whining Noise
I have a 2004 Disco and when I do a cold start-up, there is a very loud roaring noise from the engine compartment for about 2-3 minutes then it stops. I never hear it again until the next cold start-up.
Also, when I turn on the AC, there is a loud whining noise only during acceleration. When I turn the AC off, I do not hear any whining at all.
Ideas/suggestions?
Old Jul 29, 2010 | 08:28 AM
Bundu's Avatar
Banned
The loud roaring on start up is the lion waking up from its sleep, that's normal. Actually its the secondary air injection pump you hear, this only runs on cold start up for a few minutes. If it's really loud then the pump could be faulty.
The whining noise could be your serp belt slipping, check your serp belt for wear and tension.
Old Jul 29, 2010 | 08:33 AM
jkistner's Avatar
4wd High
Thanks! My brother has an 02 Disco and his doesn't make the loud noise during a cols start. Do all Disco II's have the secondary air injection pump?
Old Jul 29, 2010 | 08:36 AM
Bundu's Avatar
Banned
Not all Discos have SAI.
Old Jul 29, 2010 | 08:40 AM
jkistner's Avatar
4wd High
Lastly, it only has 42K miles. When does the serpentine belt generally need to be replaced?
Old Jul 29, 2010 | 08:45 AM
Bundu's Avatar
Banned
Check for cracks, its 6 years old and most probably needs to be replaced by now.
This is what you need http://www.roverparts.com/Parts/ERR6898.cfm
Note if you have ACE then you need a different one.
Old Jul 29, 2010 | 10:44 AM
ljdiscovery's Avatar
It could also be coming from his viscous fan clutch. In that case, that sound is a good thing, means he doesn't have to buy another one this week.........Phil
Old Jul 29, 2010 | 11:13 AM
Bundu's Avatar
Banned
Phil, for which sound? The roar or the whining?
Old Jul 29, 2010 | 02:10 PM
Wink
roar
Phil
Old Jul 29, 2010 | 03:12 PM
Bundu's Avatar
Banned
On mine the initial noise on cold startup is from the SAI pump, I can't remember the fan ever kicking in. I will keep checking.
Is there a way to test the viscous clutch?
