Loud Roaring and Whining Noise
thats the best...
The loud roaring on start up is the lion waking up from its sleep, that's normal. Actually its the secondary air injection pump you hear, this only runs on cold start up for a few minutes. If it's really loud then the pump could be faulty.
The whining noise could be your serp belt slipping, check your serp belt for wear and tension.
"The loud roaring on start up is the lion waking up from its sleep"...
That is the funniest thing i have heard in a long time....outstanding bundu!
Vibrations are an indication that something is wrong - its never normal.
First question: have you rebuilt your front drive shaft? Vibrations from 50mph onwards normally come from a drive shaft going bad.
If only at higher speeds then check your wheel balance, if the steering wheel shakes then its your front wheels, otherwise rear wheels.
Do you have non-D2 rims on your truck?
Well start by checking the u-joints and center ball joint on the drive shaft, they fail and explode your tranny. Signs of failure are vibration, chirping and a load boom. It's good preventative maintenance to haul it out and replace the u-joints and ball joint, look in the "Write ups" and "How To" section for details on rebuilding your drive shaft.
Also, when I turn on the AC, there is a loud whining noise only during acceleration. When I turn the AC off, I do not hear any whining at all.
Another one for you . . . are you familiar with the vehicle vibrating at around 75 mph. The previous owner had it checked out by Land Rover and said it was fine, but it doesn't seem normal to me.
Thanks for all your help!
As for your vibration at 75 mph, mine also does the SAME thing lol. The dealer told me that "It's normal". I haven't really investigated far into it, I'm rollin' on the original front drive-shaft, so i'm assuming that's what it is, since I have newer tires that have been freshly aligned.
The a/c compressor places extra load on the serp belt only when a/c is on and the a/c clutch has kicked in, otherwise the a/c pulley rotates free. Your serp belt slips if your serp belt tension is too loose and the a/c compressor is engaged, that is when you hear the squeal, especially when you punch the gas. The same happens if you get water splashed on the pulleys from a puddle or rain.
pierrejchan
11-11-2008 11:27 PM
