LOUD Squeaking from front wheel when turning at slow speeds or stopped
My 2000 disco started squealing / screaming when I turn the wheel either way at a low speed. I climbed under her in park and had someone turn the wheel back and forth. Sounded like it was coming from the axle cv joint area on the passenger side. Does it Sound like I need to replace the cv joint? Would it make a loud squeak noise when bad?
hub
It's definitely coming from the hub area, its a screech but not a belt type sound.
A creaking of metal type sound. Almost like an old door being opened .
Would the Hub or CV joint make this noise when the wheels are turned to the left and right?
Also could something in there cause my hill decent light to come on intermittently ? Just trying to figure out what to replace.
I can't find much on having the hill decent light on alone - without the other 2 amigos.
