loud whine noise from trans area
Old Feb 5, 2019 | 10:05 AM
Broken08's Avatar
Default loud whine noise from trans area
My 01 D2 with 140,000 suddenly started a loud whine from the transmission/ transfer case area. It is higher in pitch with speed and I can feel it in the (d1 converted) transfer stick. It is not present while coasting but is there when on the gas at all.
I plan to check diff fluid level to rule out the easy things. Any experience or thoughts? Does the transfer case have it's own fluid too?
Old Feb 5, 2019 | 10:56 AM
mollusc's Avatar
yes, the transfer case has its own fluid that's separate from the transmission fluid.
does the whine change if you shift the transfer box into a different ratio?
Old Feb 5, 2019 | 11:01 AM
shanechevelle's Avatar
You should check both the trans and transfer at least twice a year.
also grab your front shaft and twist it, makes sure its solid and not floppy at the joint.
Old Feb 6, 2019 | 09:56 AM
Broken08's Avatar
Update; diff was good, got mne fluid in.
transfer case only had 1 quart come out. Fluid looked ok, pretty good amount of shavings on magnet, no chunks. So it must have run low and dry for too long. Put in new 85/140 standard oil .A lot quieter but for sure makes the noise.
Ignore forever or replace?
Certain oil fix it better?
Old Feb 8, 2019 | 05:13 AM
this is why I change every fluid every year yes it takes a good part of the day but as far as preventative maintenance it adds miles and knowing the condition is worth the knowledge.
I dont think any oil can make it better, once the damage is done, it's done. You could experiment and see if a particular oil makes it quieter.
Old Feb 8, 2019 | 08:53 AM
wjsj69's Avatar
It's definitely only gonna get worse. And extra metal circulating will compromise everything else so, better to repair sooner than trying to nurse it along. If you've ever seen a noisy one taken apart, you'll understand why it's so important to keep up on fluids. Even if you do, sometimes they fail anyway but low/old fluids are the fastest, surest way to failure.
Old Feb 8, 2019 | 09:21 AM
Broken08's Avatar
Well I was hoping to limp this Rover along for less than another year. Not yet planning to dump another transfer case in to it so I guess all I can do is hope it doesn't grenade itself.
i assume as far as a proper repair a replacement case is the solution?
I feel like the magnet got the shavings pretty well but I'll probably do another fluid change soon to make sure I get all the shavings out.
Sad news for old Rover.
Old Feb 8, 2019 | 09:23 AM
Broken08's Avatar
here is the magnet during the change.
Old Feb 8, 2019 | 01:29 PM
Llamasayswhat's Avatar
Run it til it fails
That is a fair amount of shavings, but no chunks of gear, and as long as you dont get grinding or any other noise, it is fine.
A second fluid change in a month or two wont hurt to flush out any more garbage in there. If you want to do one every month for a few months, that would be a good way to monitor continual wear.
Otherwise, fill it and run it. the LT230 is very stout and some whine doesnt indicate imminent death.
Old Feb 8, 2019 | 02:14 PM
Broken08's Avatar
how about some redline shockproof lube? Sounds perfect
HEAVY SHOCKPROOF®
  • Film thickness greater than an SAE 75W250, yet low fluid friction like 75W90
  • For heavily-loaded racing differentials and transmissions, problem gearboxes
  • Many performance racing applications like Sprint/Midget/Dirt Late Model Differentials, Detroit Lockers and spools, NHRA Top Fuel and Funny Car rear ends
  • Not recommended for most synchro applications due to the product's extreme slipperiness
