love my ride but leaking oil.
whats up im knew to the forum. I love my 99 Disco I but I think I am leaking oil. If anyone could please help. My disco has 75k on the clock. The oil Im pretty sure is leaking of of this crossbar toward the front center of the under side of the car. I would appreciate any help.
RE: love my ride but leaking oil.
next time think of doing it yourself. That way you know it will be right. You will need a big wrech for the drain plug. Check to see if your vehicle needs a ring gasket of some kind to help. prefill your oil filter, this help prevent dry starts with the vehicle. Clean the engine, top and bottom by hand. after the change see if the problem is fixed. If not see if you can track the leak. It will help if you put something underneath to catch the oil, not only to locate the leak, but to keep the area clean. If you change the oil yourself make sure you have something to catch it in, and shop towels. The oil comes out fast and there is alot of it. Hope it helps, duboff
Darrinj123
03-09-2009 01:10 PM
rinmud
Off Topic
12-21-2008 02:10 PM
