Love the new Discovery... some minor problems
Old Mar 27, 2005 | 01:42 AM
dma3's Avatar
6th Gear
Default Love the new Discovery... some minor problems
If you remember me from a couple weeks ago, I just purcahsed a 00 Disco II (27.5k on the clock) and I'm noticed some small things. At no speed or very low speed I hear a groin when steering. This usually happens when I back out of my driveway and turn to go down the road. The other problem is periodically I have my ABS, TC and Descent lights all go on with a beep... like my ABS goes dead. I can shut off the car and turn it back on and the lights do not come back.
In reading previous posts, it sounds like this may be the ABS module going bad... there was no resolution to the previious case so I thought I would see if any of you have seen this. It also looks quite pricey to fix, but it should be covered as my Disco is LR certified (with an additional two year warantee on top of the one year that comes with the cert. My dealer is an hour away, so if this is something I could fix easily in my garage (I'm pretty mechanically inclined) I'd rather do that.
Either way, I'd welcome your thoughts...
Old Mar 30, 2005 | 05:43 PM
Texas Rover's Avatar
3rd Gear
Default RE: Love the new Discovery... some minor problems
ORIGINAL: dma3
I've only owned my 2003 Discovery for 3 months and I'm new to the forum. I don't have an answer for you, but I have a very similar problem. My ABS, TC and Descent lights all came on (with a beep) and now they stay on. (This happened the first time I applied the brakes after leaving a carwash, while brakes were wet)
I was hoping I just "fooled" some kind of sensor, however, turning the vehicle on and off does not help. Like you, I'm an hour from the dealer and don't want to travel over there if this is something I can easily reset??
I look forward to thoughts on this issues as well...
Old Mar 30, 2005 | 06:13 PM
mikemeyer0's Avatar
hey i have a 98 disco. My abs light stays on until i reach about 5 mph. About a month ago it stayed on the whole time driving. even after i shut it off and turned it back on. I un hooked my battery ground for about 30 minutes and it was fixed. I had to enter the radio security code so make sure you know it first.
Old Mar 30, 2005 | 06:30 PM
3rd Gear
I'll try disconnecting the battery (after I get the radio code) I can only hope it's that easy.
Thanks
Old Mar 31, 2005 | 02:37 AM
Bait's Avatar
Nice try, but this will not fix anything. If your lights are coming on this indicates A fault in the system. You need to get A competent shop or Dealer to investigate.
Old Mar 31, 2005 | 01:38 PM
mikemeyer0's Avatar
ORIGINAL: Bait
Yea but it could just be a fantom code, try to clear if it comes back on you have a prob. I have had 2 fantom codes so far. oh yea they were 2 differnt codes. 1 check engine and one abs.
Old Mar 31, 2005 | 05:19 PM
anonimaus's Avatar
For the ABS system, one of the most common (and recurring) problems is the the air gap being too large on one of the sensors. Check to see that the sensors are properly seated in the bushing, and (gently) tap them down if they are not. You shouldn't be able to "overdo" it, as the sensors will be pushed out to a correct distance when you start in motion. If you still have an ABS warning after this, you probably have an actual issue.
Old Apr 1, 2005 | 01:34 AM
DIMISA1977's Avatar
ahhh, the joys of disco ownership...
as a new owner, i await the misc. bull**** that will occur.
Old Apr 1, 2005 | 02:02 PM
mikemeyer0's Avatar
funny, it is always something differnt. lol.
Old Apr 1, 2005 | 04:47 PM
MiniManiac's Avatar
I am keeping my fingers crossed on my discovery. So far, so good.
