Low coolant and wet carpet
So I noticed that my coolant was low and filled it on up. After an eight hour trail session on some sweet rocks, never running hot, I got to the house and let the engine cool. I let it cool all night and in the morning noticed that the coolant was low again. I noticed that the carpet on the passenger side floor was damp when I was vacuuming the dirt out. It looks like there is some dripping from under the dash. I know that on other vehicles that there is coolant lines running under there and that this kind of thing happens but I was wondering if it was because the truck was on a steep uphill and bouncing around all day or if I have a leak under the dash. If anyone has had this problem I am looking to see what the solution is and if its feasible to fix this myself or is it a monster project?
2000 Disco II I got used with 140K currently has 144K
There is a chance its dog pee but its still wet after a day
Took the rubber line off the thing by the heater core and water went everywhere, I will follow that rubber line till i find the blockage. Any idea where the Antifreeze might be going? The engine isn't getting hot or anything.
I'd suggest getting your hands on a cooling system pressure tester so you can pressurize the system and see if you can find any external leaks. If you can't, then you can start pulling plugs to figure out which cylinder is filling up with coolant.
bcolins
Jun 29, 2015 07:22 PM
Spencerfitch
May 3, 2010 02:56 PM
