low idle on verge of stall
Hi Everyone!
I replaced my valve cover gaskets recently. After finishing, I started the beast and my idle was incredibly low. On the verge of stalling. I also got the battery light on the dash (which goes away after holding the accelerator down for a few seconds).
Any suggestions on what might have happened? What did I screw up and what should I look for to remedy this??
Thank you in advance!
assuming you connected ALL the hoses and clamped them down......
did you reuse the upper intake gasket or use a new one? Sometimes it will kink, and the new ones from AB don't exactly fit the guide pegs....
damaged the brake booster quick connect?
purge valve connections?
just a tiny leak will cause this....
kylltyme1 (04-16-2020)
