low idle on verge of stall
Old Apr 10, 2020 | 01:49 PM
kylltyme1's Avatar
8th Gear
Default low idle on verge of stall
Hi Everyone!
I replaced my valve cover gaskets recently. After finishing, I started the beast and my idle was incredibly low. On the verge of stalling. I also got the battery light on the dash (which goes away after holding the accelerator down for a few seconds).
Any suggestions on what might have happened? What did I screw up and what should I look for to remedy this??
Thank you in advance!
Old Apr 10, 2020 | 03:14 PM
Red5's Avatar
Any engine codes? Check for any vacuum leaks after the MAF, and clean the IAC with some brake cleaner if you have not lately. The batt light is prob just because the alternator is not spinning fast enough. Find and fix the cause of the idle and it should go away.
Old Apr 11, 2020 | 03:16 PM
XRAD's Avatar
assuming you connected ALL the hoses and clamped them down......
did you reuse the upper intake gasket or use a new one? Sometimes it will kink, and the new ones from AB don't exactly fit the guide pegs....
damaged the brake booster quick connect?
purge valve connections?
just a tiny leak will cause this....
Old Apr 11, 2020 | 06:18 PM
Best4x4's Avatar
yep sounds vacuum related for sure
Old Apr 15, 2020 | 04:22 PM
kylltyme1's Avatar
8th Gear
Thank you for the heads up. I did throw 2 codes:
- P1121 - Intake Air Temperature Sensor
- P1131 Knock Sensor
Haven't found anything about those two on the forum.
Old Apr 15, 2020 | 04:24 PM
kylltyme1's Avatar
8th Gear
Hmmm... I did replace the upper intake gasket but it went on without a hitch. Seemed good to me but I'll double check. I did buy a new purge valve so maybe it might be time to replace that as a fail safe?
Old Apr 15, 2020 | 07:03 PM
XRAD's Avatar
leaky valve cover gasket? somewhere it's pinched?
Old Apr 16, 2020 | 03:03 PM
redwhitekat's Avatar
If it was running fine before you took stuff apart than it’s probably something simple that you did
Rovergang
Jan 24, 2017 07:10 PM
98discoj
Nov 26, 2014 05:11 PM
94svt50
Mar 6, 2011 09:10 AM
roverboy
Jan 4, 2009 10:10 PM
rravenn13
Jul 19, 2007 04:40 PM
