Lower Intake Manifold Leak...Help!!
Old Feb 16, 2008 | 11:57 AM
jkid's Avatar
Default RE: Lower Intake Manifold Leak...Help!!
ORIGINAL: dragon_avaloch
Also, what the heck is a BG nitrogen tire service?
Sounds similar to a muffler bearing service or a blinker fluid flush.
Old Feb 16, 2008 | 12:01 PM
dragon_avaloch's Avatar
LOL, sounds like I should give them the 30 bucks to get it done then. Blinker fluid flush, love it.
Old Feb 16, 2008 | 12:49 PM
jkid's Avatar
I have heard of putting Nitrogen in tires, but I didn't think anybody actually did it. Reminds me of when I was working in a shop/warehouse, we used to "change the tires from summer to winter air" when things were getting slow.
Old Feb 16, 2008 | 02:39 PM
okdiscoguy's Avatar
They fill aiplane tires with nitrogen because it isn't affected by temp changes. I used to maintain fuel tank gauging systems that used a pressure gauge and nitrogen in transmission lines. People fill tires with nitrogen so you don't have to change the pressure in winter and summer, and it doesn't get higher when the tires heat up. When I worked on the fuels systems, the Nitrogen was free for me, and I had the tires in my Volvo filled. I never had to adjust pressure again...
Old Feb 16, 2008 | 05:31 PM
You might want to call me.
Don't do the B&G gas in the tires, it is a rip off.
303-862-7680
Colorado before 8 pm
Old Feb 16, 2008 | 06:51 PM
elrocha69's Avatar
That is way way too much to change the intake. the lower intake is alot like a small block chevy V8. the upper intake is not hard to remove at all. can easily be done in about 25 minutes, 10 if you have done it more than once. lower intake isn't too much harder. once everything is out of the way. just drain the coolant first to minimize the mess. it unbolts just like on an old chevy 350 v8. disconnect the fuel rail and injector wires and other sensors and its pretty easy. I'd try a reputable shop that specializes in european cars. may cost a little bit more than say Firestone and Pep Boys but is definately worth it, because they know wehat other things to look for while performing the repair. these fast food chain versions of mechanic shops usually just blindly perform the repair and don't take the time to really look at your truck while it is apart. Now don't get me wrong there are some pretty good mechanice at some of those shops but hopw do you know who they are, unless you are a mechanic yourself. I hope this helps you some.
Old Dec 25, 2008 | 11:45 AM
kavik's Avatar
Don't mean to bump an old post, but my 02 discovery has a leaking intake manifold gasket as well, with a $1400 estimate from the dealer to fix, so I am looking at doing it myself. I read the above post and searched, but couldn't find the "60k service" things to check while I'm at it. The vehicle is at 85,000 miles.
I was also wondering if anyone has a service manual/parts diagram for the gasket replacement , id anything but the kit is required (ie sealant, etc) and torque values/etc for the bolts.
thanks
Old Dec 25, 2008 | 01:51 PM
You could have a porous block or head, I would get a second opion from a good non dealer shop.
Get nack to us and let us know what you find.
Old Dec 25, 2008 | 02:32 PM
mwindth's Avatar
Kavik...here is the 60K service as prescribed by Disco Mike...I would check if your front u-joints are grease-able as well (if not, replace as well with Precision part#344 and #617).
This is the parts list for a 60,000 mile service or a high mileage used truck, the way I do it.
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Air filter
6 Qts of engine oil
12 Qts of ATF
7 Qts of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of synthetic Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platium Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
Hoses and belts, as necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Change the coolant and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Normal 0 false false false MicrosoftInternetExplorer4
Old Dec 26, 2008 | 08:15 AM
Cessna310Guy's Avatar
Do the intake gasket yourself, I did a couple weeks ago and it was a breeze. I had roughly 13 hours in it and cost me like disco mike says, around 100 bucks. If you get under the truck and see coolant leaking down around the bell housing onto the cross member bar it's the same symptoms I had.. I was going through roughly a litre of fluid every few days of constant driving. Now, I have been checking it every week and she is holding steady now and have not had to add any at all. I am by no means a mechanic but this was something fun to tackle and allows you to learn about your vehicle in a way that most people don't... GO FOR IT, and we are always here to help...
