LR D2 MAF Sensor Recommendations
Anyone have a recommendation for a MAF sensor.
Should I "bite the bullet" and go with the OEM Bosch or use a different (read cheaper) manufacturer.
FYI, I have a 4.6HSE with secondary air (that's what the air injection system is called, right) so the intake and throttle throats on the MAF body are a little bigger (~4mm) than non-SA motors, right?
Searched the forum but did didn't get any results in spite of this being a common maintenance part (right?).
And should I buy just the sensor or the whole body?
@austinlandroverbill I would 100% recommend getting the Bosch part. I bought a used MAF and ended up being bad, threw a check engine light etc. Bought the Bosch MAF and have been good to go.
I think most folks will tell you that D2's really like the Bosch parts. Seems like it's worth buying the right stuff.
I bough the whole MAF assembly off of parts geek for $130 or so. Best price I found on genuine Bosch. You can buy just the sensor, but you will need the right tool to pull it out.
Thanks.
I pulled the sensor and cleaned it already, so no biggie there -- used a security bit set from Harbor freight, worked fine.
Again, my worry is that if I buy an MAF sensor + body, I may get the slightly smaller one for non-secondary air vehicles that wont fit the airbox or throttle body ends.
Any Bosch part number for a secondary air equipped 4.6 HSE?
Wheelspin (10-03-2020)
For what it's worth, I stumbled across some info on Tornado Systems website, the guys in the UK who do re-mapping of the V8 ecu. They recommend changing the MAF after 80-90k and say that the ECU is sensitive to the original Bosch part (MAF) if a re-mapped ECU is used. I have a stock ECU, so I have no experience with this, just found it interesting to consider. I can't find a history item for my '00 saying the MAF was ever changed, so i believe mine is original @ 160k miles. I can see the desire to go aftermarket with this part tho, the price difference between it and the Bosch part is pretty big.
Rhys L.
Rhys L.
