Lr disco jumpy! Help please!
My 02 land rover disco series II is acting crazy. It only has 45k miles on it. It idles heavy and when I go up a hill it kinda stutters. Almost like it's missing gears but it's not. It's just real jumpy. I thought it may have been the cadillaic converter so I had that changed, but it's still doing it. Any ideas on what it might be?
Thanks!
Thanks!
For the time, money, aggravation you put into it, you'd have been better off buying a code reader for $50, or taken it to a shop and gotten a free quote.
crappy gas
bad plugs
bad wires
bad coil(s)
bad o2 sensor(s)
carboned up
The catalytic converters can make it sluggish, but usually you'll see a check engine light, and I've not heard of them causing "jumpiness"
luck,greg
crappy gas
bad plugs
bad wires
bad coil(s)
bad o2 sensor(s)
carboned up
luck,greg
Why do people like to guess, make repairs and then wonder what is wrong?
Do you have a check engine light on, if so, what are the 4 digit fault code numbers?
As for your cats, if they were bad, they were still under a State or Federal emission warranty.
Be more specific as to your description as to what is wrong,acting heavy doesn't tell us much.
By the way, what octane gas are you burning?
I'm using 92 octane which is what it calls for. The service engine light is on, where do I find the codes? I can't really explain what it's doing. The engine light has flashed before and the car acted like it had no power at all. I thought I was breaking down and then it accelerated...if that helps anymore? Thanks for the replies!
+1 - the exact same thing happened three weeks ago to my vr6 jetta. Coil and wires
