lube questions
Old 12-13-2010 | 06:18 PM
halfassedastronaught's Avatar
5th Gear
Default lube questions
I remember reading on here some time ago about rotella 15w40 motor oil....and a wix filter. Is this the right stuff to buy for houston tx climate. I just want to confirm before i change it. seems i remember alot of good comments about this oil and a wix filter. just wanna make sure its 15w40. and what the filter number was. 2003 disco
Old 12-13-2010 | 07:01 PM
lipadj46's Avatar
yes 15w40 is correct, you can also try the 5w40 synthetic. Wix filter is 1515 (or 51515 forget which), that is the larger filter.
Old 12-13-2010 | 08:16 PM
For TX you can use the 15w-40 year round.
Old 12-13-2010 | 08:42 PM
buick215's Avatar
You can also use the Mobil 1 301 oil filter, it is longer than the regular one.
Old 12-13-2010 | 08:49 PM
FightOnUSC79's Avatar
What would you suggest for AZ? it is basically hell for half the year so I'm looking to get the best protection possible.
Thanks in advance
Old 12-14-2010 | 08:21 AM
texmbr's Avatar
Went to 15w40 Rotella in both our Disco's and like it. In Texas good year round and great cleaning qualities.
Old 12-14-2010 | 02:51 PM
KyShark's Avatar
Any recommendations for Kentucky? It generally doesn't get below 0 here, though it might once or twice. Am also concerned about MPG... is 15w going to slow it down too much?
Old 12-14-2010 | 04:16 PM
texmbr's Avatar
I did not notice any loss of MPG at all with 15w40. Now I did when I switched to 75w140 synthetic gear oil in transfer case and diffs.
Old 12-14-2010 | 06:04 PM
lipadj46's Avatar
15w40 is fine for temps above 32F. Under 32F you will start getting some unhappy valvetrain noises. Personally I like using synthetic 5w40 as it is only $15 more an oil change but I live in Buffalo so there is no way I would use 15w40 in the winter.
Old 12-14-2010 | 08:27 PM
KyShark's Avatar
Pardon my ignorance, but does unhappy here mean harmful or just an annoyance? With a truck I don't have the service history for I'm liking what folks are saying about the detergent qualities of the 15w40 rotella.
Quick Reply: lube questions
