Lubricant
Old Apr 11, 2011 | 02:27 PM
FightOnUSC79's Avatar
Default Lubricant
The summer has started here in AZ and am wondering what the best lubricant for doors, latches and sunroof tracks would be?
Thanks in advance
Old Apr 11, 2011 | 02:38 PM
buick215's Avatar
Wurth spray grease called HHS-2000 is the best or you can use white lithium grease. Don't use WD 40 or PB blaster, they are too thin and will dissolve the grease that is already there.
Old Apr 11, 2011 | 03:32 PM
Disco_Fever's Avatar
Wurth is very good $tuff.
Old Apr 11, 2011 | 04:15 PM
photocrimes's Avatar
I use white lith on everything but the pivot pins on the rear door lever. Those seem to stick on the d2 with anything other than wd40. I just pop the logo off and give it a spray every once in a blue moon.
Old Apr 11, 2011 | 07:40 PM
Silicon spray on the hinges latches and locks.
Bike chain lube on the cargo door stay.
Neither lube will attract dirt.
Old Apr 11, 2011 | 07:53 PM
narleyman63's Avatar
I use silicon and Justice Brother JB80.
Old Apr 11, 2011 | 09:08 PM
grandkodiak's Avatar
seafoam spray works rather well, foams up like moose and settles itself in places i didnt think possible haha
Old Apr 11, 2011 | 11:45 PM
mwindth's Avatar
You surly do not mean using this as lubricant, right? Am I missing something Sea Foam | Sea Foam Spray ?
Old Apr 12, 2011 | 08:15 PM
deep creep rather gets behind and around all the crud ive found and forces it out... wipe it a few times as the residue slimes out over time, love the stuff.
bobco
Mar 26, 2012 07:05 PM
kpl1228
Mar 11, 2012 07:47 PM
CANAMDiscovery
Jan 30, 2010 09:20 AM
malmberg
Feb 24, 2009 01:40 PM
khandrh
Aug 9, 2007 09:56 PM
