Lubricant
Old Aug 9, 2007 | 03:46 PM
khandrh's Avatar
Default Lubricant
I want to lubricate the hood latch, door locks, fuel door hnges etc. I was told that I should do it with a silicone lubricant as oppose to WD40.. Whats best...
Rolando
Old Aug 9, 2007 | 03:50 PM
98roverguy's Avatar
Default RE: Lubricant
I think lithium grease would do it as it doesn't run-off like WD40. But I've never done them (I should). Someone will chime in.
Old Aug 9, 2007 | 03:51 PM
S4poor's Avatar
PB Blaster. It loosened stubborn blots, but also remains on that area unlike many other lubricants.
https://www.expeditionexchange.com/series/
Old Aug 9, 2007 | 04:06 PM
SpeedAgent's Avatar
I would use the silicone. PB and WD-40 are actually penetrants and unless you are trying to remove the hood bolts or hinges you don't want that. Use the silicone spray.
Old Aug 9, 2007 | 08:07 PM
Stay away from the penetrating type fluids, the white grease work well but aree a little messy. There are some new synthetic light grease that when put on in small amounts will last forever.
Mike
Old Aug 9, 2007 | 09:56 PM
okdiscoguy's Avatar
just an FYI. when WD-40 dries, all of the good stuff evaporates. Good for penetrating, but not long term lubrication.
This is what I use, but don't know where you can get it. Unless you live in Tulsa......I'll give you a can.
http://www.royalpurple.com/prodsa/mfilma.html
bobco
Mar 26, 2012 07:05 PM
kpl1228
Mar 11, 2012 07:47 PM
FightOnUSC79
Apr 12, 2011 08:15 PM
CANAMDiscovery
Jan 30, 2010 09:20 AM
malmberg
Feb 24, 2009 01:40 PM
