LUCAS OIL QUESTION
Old Nov 2, 2008 | 03:29 PM
malmberg's Avatar
Default LUCAS OIL QUESTION
I am going through and working on disco mike's maintenance schedule and I had a couple of questions. I purchashed the 7 quarts of royal purple 85w140 and I was wondering how much lucas should I be adding to each diff and the transfer case. I am also flushing the power steering fluid and was wondering how much lucas to add to that also. I live in the Palm Springs California area which is desert heat if that has anything to do with it. Any help would be greatly appreciated.
Old Nov 2, 2008 | 04:14 PM
Disco2Guy's Avatar
Default RE: LUCAS OIL QUESTION
Put the whole bottle in the t-case and p/s reservoir.
Old Nov 2, 2008 | 04:28 PM
If your using full synthetic why even use a additive?
In my humble opinion if you need a oil additive then you need a different oil.
But thats just my 2 cents.
Old Nov 2, 2008 | 10:02 PM
Jupiter Rover's Avatar
WOAAA do NOT use lucas oil additive. DO NOT use LUCAS OIL additive. ONLY the gasoline additive is good.
Old Nov 2, 2008 | 10:03 PM
DO NOT ADD ANY ADDITIVE TO ROYAL PURPLE OIL. IT IS NOT LIKE NORMAL OIL IT HAS ITS SYNERLEC TECHNOLOGY. IT DOES NOT NEED AN ADDITIVE.
Old Nov 2, 2008 | 10:04 PM
DO NOT PUT IN STEERING ADDITIVE. IT IS NOT NEEDED WHATSOEVER.
Old Nov 2, 2008 | 10:06 PM
LUCAS TEST: failed, No tricks.
Royal Purple is an AMAZING oil. just leave it alone.
Old Nov 3, 2008 | 08:39 AM
discoxd's Avatar
Default Re: Lucas oil question
thats some pretty interesting information you have provided us with... thanks
________
Washington medical marijuana dispensary
Old Nov 3, 2008 | 08:47 AM
Because you are going with the heavier 85W/140, no additional Lucas is needed.
As for the power steering, use only 1/2 of the small bottles of Lucas. If you are using any in your tranny without synthetic ATF then use a while bottle of Lucas tranny additive.
Old Nov 3, 2008 | 05:37 PM
malmberg's Avatar
I wish that I would get emails in my garage. I have already added 1 pint of lucas to both diffs. Luckily I didn't put any in the transfer case. Is it going to be alright with mix in the diffs ordo I have todo another flush ???
