Lucky 8 Ignition Barrel problems?
Hey all.
So I have posted a bit quick here on my last two post. I've quickly found other remedies but with this one I cant.
I purchased a lucky 8 Ignition Barrel that comes with a set of keys. It will not turn at all. Is there something here I'm missing? Do i have to take it to a locksmith to get these keys working? It was supposed to be turn key. Just to make sure it wasn't anything else I took the wiring harness and put a flat head into it and turned the electronic part. Smooth as butter and have dash lights for the first time since owning it.
No matter what I hold down on the Ignition barrel, and no matter how much fidgeting with it, I just cant get it to turn. In the disco ready to be used, and or out of it holding in the retention tabs.
Nothing is working. Thoughts, comments? Thanks in advance.
Unlikely to be this, since the OP says that the barrel won't turn even if it's out of the vehicle.
Anyone else have this issue?
