Sponsored by: CARiD
Key broken off in ignition 2000 Disco Series 2
Old Dec 27, 2014 | 04:09 PM
Jvirgo416's Avatar
5th Gear
Default Key broken off in ignition 2000 Disco Series 2
So yesterday a small piece at the end of my key broke off in my ignition in the off position. Spent an hour or so trying to get it out, neither could a locksmith. Does anyone have any experience getting the barrel out and if so can you get the piece out of the barrel when you do? Any advice would be greatly appreciated. Thanks
Old Dec 28, 2014 | 01:53 AM
abran's Avatar
Attached is a link in the D1 sticky section for tumbler removal/repair.
I'm pretty sure they are close enough in structure that this would work.
In the end you might need to buy a new ignition and door handle with matching key if you want to have one key.
In the meantime at the back of the ignition barrel is the connection to the wiring harness. Unscrew both small silver Phillips screws and pull off black round connector. This will expose a slotted key hole type section, insert flat head screwdriver, turn clockwise to start your rover.
Good luck
https://landroverforums.com/forum/discovery-ii-18/ignition-lock-fix-35422/
Old Dec 28, 2014 | 02:19 AM
abran's Avatar
I just realized that is a D2 ignition in the thread. Follow directions exactly.
ls1morethanyou
Mar 11, 2014 07:57 PM
will rocket
Off Topic
Sep 12, 2013 06:23 AM
targotsi
Jan 22, 2010 02:32 PM
ropadope
Oct 5, 2007 07:30 AM
stevelg
Sep 7, 2006 02:20 AM
