Lucky8 Ignition Retrofit
Old Nov 23, 2021 | 06:55 PM
604x4BC's Avatar
Default Lucky8 Ignition Retrofit
Has Anyone done this, and if so any instructions/how-to's maybe already posted someone could direct me to?
Search is pulling up too many irrelevant results to sift through...
https://lucky8llc.com/collections/di...-kit-with-keys
Got this in the mail today...I wish L8 sent instructions for the stuff they sell...
This one looks different that what Atlantic British is selling, seems likes its missing the wiring? Can I follow the video AB has on the install?
Old Nov 25, 2021 | 06:09 AM
SundayFunday's Avatar
I recently replaced the tumbler with a new old stock I sourced. I remember that video as a general guide.
It Was simple & no programming device needed
Old Nov 25, 2021 | 08:03 PM
Sandman614's Avatar
Pretty straight forward disassembly and install. That's a good video. What are you worrying about?
Old Nov 26, 2021 | 01:18 AM
Frank4's Avatar
I installed this on mine a couple years ago. It looks like it’s missing wires because it is. Your original unit requires you to have the key in the ignition to shift out of park. This part does not accommodate that function and therefore doesn’t have the wiring. Still a straight forward install, there is a connection you won’t use that plugged into the original unit. Just zip tie it to keep it out of the way when you are reinstalling the steering column cowl.
Old Dec 9, 2021 | 04:10 PM
WaltNYC's Avatar
I have a D1 and am considering this. If the truck is in 'D' and I attempt to start it, what happens? Just a lurch ala a manual with the clutch out?
Old Dec 9, 2021 | 07:03 PM
JohnZo's Avatar
Default Rover key needs to be wife friendly
I was having trouble with my worn out keys engaging properly. Had to fidgit around to get it to turn. So, I dismantled the mechanism, filed down some of the brass parts a bit, deleted the key-in lever. Now it is smooth as silk, yet my other LR key does not activate, so it still functions well for security. It's fairly complex and took some head scratching to figure out all the mechanical bits, but it is able to be repaired rather than replaced, and keep the key same as the doors. I did not use shear bolts to re-assemble to the steering shaft, rather used regular bolts from the hardware store, so I guess I'm more at risk of thievery.
Maybe runs in the family. My mom tells of Grandpa rigging up the '36 Chev to start with a screwdriver...
Old Dec 10, 2021 | 06:42 AM
WaltNYC's Avatar
I have done this but now the key can be removed in position 'I'. The idiots at the parking garage continually leave the car with the key in position 'I' and run down the battery. So I am basically idiot-proofing this for the goons at the garage.
Old Dec 10, 2021 | 12:26 PM
H Hill's Avatar
I have done this, no worries, just follow the video information. Remember that this key also has no built in "fob" so you will need to continue to use the old key for for fob/door and this new key for the ignition.
Old Dec 11, 2021 | 11:57 AM
JohnZo's Avatar
When I filed down the tumbler, I only touched the tabs that were slightly high with the key fully in. So, it continued to work normally to retain the key in all positions except zero (0). Once all the tabs are flush with the key in, no more filing is needed. Then I used a dab of silicon caulk to retain the side pin that holds the barrel in place.
Old Dec 12, 2021 | 08:22 AM
The_OGCJR's Avatar
it won’t start.
the ignition will let you take key out in D but you won’t be able to start in D
