lug replacements
Strange. I tried a 27mm and it didn't quite fit. I know people say this is a sign that someone used the wrong size socket and jacked up the lugs... but they look perfect. Maybe I'll try the 27mm on all lugs and see if it fits on any of them.
I will also try the 1 1/16 and see how that goes.
Thanks again. This forum is truly invaluable.
Thanks. I will head over to Autozone and pick one up. The biggest they had at harbor freight was 27mm which didn't fit the couple lugs I tried.
The correct size is 27mm. If you need a 28mm then your caps are buggered. If you use a 28mm on lug nuts that aren't already buggered, they soon will be.
You can use an impact wrench to remove them without issue (provided you're using a 27mm socket).
You can use an impact to install them if you set it to the lowest torque and finish by had torquing.
More often than not a tire shop ruins them by using the wrong size socket (or a 12pt socket), not from using an impact wrench.
Never use a 12pt socket on them.
