MAF from hell ...
Old Oct 30, 2014 | 01:44 PM
davecason's Avatar
Unhappy MAF from hell ...
Hi,
OK, well so far we have a new MAF, and now new plugs, and 4 new O2 sensors, and now I just put in two new coil packs, and we're still seeing:
P1172
P0171
P0174
P0102
P0734
and six P1884's
Good god please help !
Cheers'
Dave
Old Oct 30, 2014 | 07:34 PM
dusty1's Avatar
vacuum leaks?, injector problem/clogged?, fuel pressure?, bad ground???, sensor plugs not making connection?
just some ideas...a lot of codes = a lot of ideas
Old Oct 30, 2014 | 07:53 PM
Fivespddisco's Avatar
When you're clear the codes and run the truck what is the first coast you get?
Old Nov 5, 2014 | 03:33 PM
davecason's Avatar
Unhappy Yesterdays codes .....
Hi,
I did a scan yesterday and cleared them - I'll get another reading today .....
It stalled 3x's on the way home.
Yesterday
P0171
P0102
P1884
P1175
P1412
P0174
P1172
And this is with new plugs and coils packs and 4 new O2 sensors .....
Cheers'
Dave
Old Nov 5, 2014 | 03:36 PM
davecason's Avatar
Default connectors?
Yea,
I was thinking that because there are some days where it runs happy as well but how do you
check for those ? I've ran some throttle body cleaner thru it and it just had a bottle of fuel injector cleaner two weeks ago .....
Should I look at getting a new short cable from the MAF to that plug on the block ......
When you say back ground ..... do you mean the battery?
Cheers'
Dave
Old Nov 7, 2014 | 08:37 PM
davecason's Avatar
Default After the codes were cleared ....
Hi,
OK here the next set I got from today ...... driving along at about 50MPH.
I got ...
P0171
P0174
P1175
Parked the truck for about 2 hours and when I came out:
P1884
P0102
Cleared them again so we'll see tomorrow! Any suggestions or ideas?
Cheers'
Dave
Old Nov 7, 2014 | 10:36 PM
WNYErikDiscoII's Avatar
Former Sponsor
Check the F2 fuse under the hood (15 amp)
Old Nov 11, 2014 | 09:09 PM
davecason's Avatar
Default get a new one?
HI,
So when you say check the fuse - just see if its intact ?
What is it for and should I just buy a new one?
It's been real cold here for the past week, and now not a single code has come up.
Cheers'
Dave
Old Nov 11, 2014 | 10:36 PM
dusty1's Avatar
f2 feeds...purge valve, o2 sensor, maf sensor, crank position sensor.
I still say check connections, very well. check wiring loom around back of engine, too.
I find it interesting that it is cold and no problems.
Old Nov 12, 2014 | 08:35 PM
davecason's Avatar
Default interesting .... well one choice of words
Hi,
Yep, thats one word for it interesting .... the other one would be PIA. (grin)
You got me - it was intermittent and now that's colder -5 to -18 deg C no errors at all.
I'll actually replace the fuse and not even fart around with it. I did that with a relay once and it fixed some stuff too. The entire fuse box was replaced once by the local pirate dealer for +$1500 and they said it has to be done. Should I be looking for a crappy repair job and maybe do the fuse and check the fuse box in behind?
I'm open to suggestions ..... Massive Thankings ....
Cheers'
Dave
