MAF Issue with Codes P0171, P0174, P0734
Old Jun 13, 2011 | 04:43 PM
Belthasar's Avatar
Default Possible MAF Issue? (Codes P0171, P0174, P0734)
Hey All,
I was just reading on a separate thread that Codes involving "lean" and a transmission fault point to a MAF Sensor issue... Well, I just got my code reader last week and finally got to driving the D2 Today and I found the following:
P0171 System too lean, Bank 1
P0174 System too lean, Bank 2
P0734 Gear 4 Incorrect Ratio
DiscoMike, you mentioned in this other post that these types of codes point to MAF Sensor issues, how does the P0734 relate? I am simply interested in understanding it better.
Also, Is this a scenario where it calls for replacement or some other type of service to be done to check the MAF more thoroughly?
Last edited by Belthasar; Jun 13, 2011 at 04:51 PM. Reason: Rephrased title as a question.
Old Jun 14, 2011 | 01:27 PM
Belthasar's Avatar
btw: am running a purolator paper filter, no modification to box or air intake in any way.
Old Jun 15, 2011 | 08:30 AM
When the MAF has failed part of the signal that the tranny computer depends on is now missing so, as in your case, you will throw an 734, tranny out of ratio code and it won't in fact shift correctly.
Buy a new MAF from British Parts of Utah, best price around for the correct NAF.
richo888
Jul 19, 2013 09:40 AM
Robover01
Jan 9, 2010 03:11 PM
utunes
Apr 20, 2008 12:55 PM
mikedemet
Apr 13, 2006 01:05 AM
