MAF Problems
Old Dec 3, 2009 | 09:41 PM
JHDisco2's Avatar
Default MAF Problems
2000 Disco2.
I replaced the MAF with a new one a few months back (Bosch OEM) and it has already gone out again. My filter is clean and all seals around box are tight. Only used compressed air to clean.
Got the same codes from the OBD2... p0171,p0174, and p0112.
What else could be messing up my MAF. (no K&N)
Thanks,
Jeff
Old Dec 4, 2009 | 12:37 AM
Slepexus73's Avatar
7th Gear
How do you know that you got the proper MAF? Scan the car and post the codes up.
Old Dec 4, 2009 | 08:45 AM
hilltoppersx's Avatar
what was the part # on the MAF you bought?
Old Dec 4, 2009 | 09:46 AM
JHDisco2's Avatar
MAF (Bosch) is from the dealership. Codes are in the original post.
Old Dec 4, 2009 | 09:55 AM
whats the mileage on your truck? what plugs and wires do you have on it? what grade fuel do you use? have you done a seafoam treatment?
Old Dec 4, 2009 | 09:59 AM
112, intake air temp. circuit low. I go by the dealer and show him your codes, you have a 1 year warranty and it should be covered as a failed MAF.
Old Dec 4, 2009 | 10:03 AM
JHDisco2's Avatar
138K on the clock, new NGK Iridiums last month, 8mm magnacores, as far as the sea foam, I use it regularly in the gas but have not done the intake procedure yet.
Old Dec 4, 2009 | 10:41 AM
i agree with mike i would bring the MAF back to the dealer and say WTF? see if you can get a new one to try.
Old Dec 4, 2009 | 01:14 PM
JHDisco2's Avatar
I agree also but what I'm trying to get at is what is frying the MAF's every time I put a new one in.
This is the 3rd time.
Old Dec 4, 2009 | 01:39 PM
lipadj46's Avatar
What kind of air filter do you use?
