MAF Ring / Airfilter Change
Old Jan 22, 2008 | 05:20 PM
ccvalentino's Avatar
Default MAF Ring / Airfilter Change
Hi,
While referring to the RAVE CD for an air filter change I found that it specifies removing the MAF sensor, replacing the Air Filter, and then replace the MAF O-Ring? Is this necessary?
Chris
Old Jan 22, 2008 | 05:21 PM
okdiscoguy's Avatar
Default RE: MAF Ring / Airfilter Change
Makes getting in the box easier, but not necessary if you can get in there.
Old Jan 22, 2008 | 06:02 PM
So, you may not have to remove the MAF sensor as specified?
Chris
Old Jan 22, 2008 | 06:18 PM
okdiscoguy's Avatar
I'll let someone with a D2 verify, but I didn't on mine, and I don't think I did on my friends 01.
Old Jan 22, 2008 | 06:39 PM
jkid's Avatar
You're not really removing it. Just unclip (see the two clips) the intake hose/mafassembly from the air filter box. It just makes it easier to get the filter cover off. I didn't replace my o-ring, but then again I'm still having this weird, bad MAF symptom.
bergin90
Dec 10, 2014 01:16 PM
Discolife
Dec 19, 2012 08:39 PM
Jay5oh
Mar 1, 2011 10:15 PM
avking
Jan 15, 2009 12:04 PM
2000 Disco 2 SD7
Jul 18, 2008 03:06 PM
