MAF Sensor
Old 03-28-2018 | 12:52 PM
JUKE179r's Avatar
Originally Posted by Best4x4
I personally just remove the darn MAF itself and install it into the housing I need to as the actual sensor itself is the exact same. I then install them into the MAF housing with some phillips head SS screws vs the security bit screws they come with. The housings are the only part that is different between 4.0/4.6L engines.
hey Best... can you post a picture of how you installed the sensors?
Cheers!
  #32
Old 03-28-2018 | 01:19 PM
Best4x4's Avatar
Sure I’ll snap a pic of the SS screws I used.
  #33
Old 03-28-2018 | 07:35 PM
Best4x4's Avatar
Sorry for the kinda rough pic, it was dark by the time I got home. With a normal screw vs security bit head swapping out the sensor is a snap.
  #34
Old 03-29-2018 | 10:24 AM
CollieRover's Avatar
Have to say with the new plugs, wires, coilpacks, sensors, and MAF the Rover is idling much more smoothly. It sort of had a lunging aspect to it.
  #35
Old 04-01-2018 | 05:20 PM
mr. choodles's Avatar
@Best4x4: Do you have a picture that shows the MAF body from the inside after the screws have been installed? Wondering if the screws go all the way through the wall of the MAF body, and if so, do they impede the flow of air?
  #36
Old 04-01-2018 | 08:46 PM
Best4x4's Avatar
I removed the OEM security bit head screws & replaced with #2 phillips head stainless steel screws of the same length.
KlamathMatt
04-17-2020 05:27 AM
pilsner
08-06-2008 10:20 PM
vjm530
07-16-2008 03:40 PM
vjm530
07-07-2008 08:19 PM
Different Drummer
10-01-2006 07:03 PM
Quick Reply: MAF Sensor
