magnacore 7mm wires and +4 plugs?
Old Feb 16, 2010 | 06:13 PM
03discoman's Avatar
Default magnacore 7mm wires and +4 plugs?
hey guys,
i picked up some magncore 7mm wires from AB and some bosch +4 (4418) for my new motor install this week... whats the word on these wires.... i was told that they are the same as 8mm wires.... just thinner jacket!!!!
are the guts the same? i've also been told that you have to havea 8mm wire to run +4 plugs....
i didnt know i was going to get 7mm wires... i thought i would have gotten 8mm..... so will this combo still work?
Old Feb 16, 2010 | 06:25 PM
lipadj46's Avatar
Buy the 8mm's from apex performance for $85. AB say 7mm right in the description, I would return them and get the wires from apex.
Old Feb 16, 2010 | 06:35 PM
03discoman's Avatar
i ordered over the phone... nobody told me they were 7mm.... i only knew of 8mm wires......
i guess the conductor size difference is .01mm (1.9 vs. 2.0 mm).... does anyone have anyword on the 7mm wires being used with these plugs
Old Feb 16, 2010 | 09:08 PM
I dont see a problem.
I prefer Iridium plugs but you can use anything you want.
Old Feb 16, 2010 | 10:48 PM
Rover Curious's Avatar
I'm using +4's with STI wires, and I'm not having any problems at all. I haven't pulled the plugs to look at them since I installed them, but my motor runs strong.
Old Feb 17, 2010 | 12:45 AM
discoboy's Avatar
While on the topic of spark plugs, I installed STI wires and +4 on the 00 Disco, but used Iridiums and STI wires on my 03 Disco. I noticed the 03 seems to idle a little rough compared to the 2000, is it just me or does the 4.6 motor rougher than the 4.0?
Old Feb 17, 2010 | 08:01 AM
okdiscoguy's Avatar
After everything that has been said about getting 8MM wires, you bought 7mm?
The conductor is the same in both, but the insulation is heavier in the 8MM. The reason it is needed is you have an aluminum engine which retains the heat long after you quit driving. If there was a cooling fan or side vents, it would be better. These things just cook everything under the hood. The insulation breaks down on the 7MM and they trace spark outside the jacket. Not all of the spark gets to the plug, and the +4's need everything to work right. They will work, maybe even up to a year. I will bet you will get a mis-fire within 2 years.
The iridium plugs do not run as well as the +4's or even the stock. Stock plugs run fine, but the +4's give you a little more torque on low range. Mike ran them for a year or so and went back.
Old Feb 17, 2010 | 10:00 AM
03discoman's Avatar
"After everything that has been said about getting 8MM wires, you bought 7mm?"
Did you not read what i posted? sometimes i swear......i donno
Since i ordered over the phone asking for magnecor wires , the sales person didnt tell me they were 7mm,i'm gonna stick with them for now and if i get a misfire, i'll go with iridium plugs or stock, thank you to the people who posted about using 7mm wires with +4 plugs
Old Feb 17, 2010 | 11:42 AM
okdiscoguy's Avatar
The iridium plugs will run worse than everything on 7MM wires and they don't run as good as the +4's on 8MM. I would send the wires back, if it was me...Get the 8MM so you don't have to chance it. IF for some reason you stay with the 7MM wires, run the stock plugs.
(did YOU not read what I posted?)
gets frustrating when someone asks a question, but doesn't give all of the information. You have 2 sets of STI wires. I am still wanting to know if they are 8MM. If they are, get your money back on the Magnacors and run the STI's. They are good wires and will be better than the 7MM. I have also already answered this question for you, along with several other people.
The way I read, the people that responded were commenting on the plugs, not the fact that your wires are 7MM.
Old Feb 17, 2010 | 10:56 PM
starrock's Avatar
back it up
