Magnecor Wirers
Old Oct 2, 2007 | 07:21 PM
  #21
Landzu's Avatar
Default RE: Magnecor Wirers
Someone let us know if they are the real thing when you get
them in.
I can use a back up set at that price.
Old Oct 3, 2007 | 09:31 AM
  #22
Aquaholic's Avatar
Just use a credit card with good customer service - and if they're not correct you can have the charge reversed.
Old Oct 3, 2007 | 10:16 AM
  #23
okdiscoguy's Avatar
Just an FYI, I ordered some this morning. Part number is 80142 for the 8MM. That is the right number for the 8MM for the D1's. We'll see...
Old Oct 3, 2007 | 10:49 PM
  #24
Willie 00D2's Avatar
I just bought my 8 mm Magnacores from roverconnection.com for $112.00 Had them 2 day later. I was able to install them without removing the intake, It took 1 1/2 hours, and was pretty easy. Now my misfiring is gone. The 2 shortest wires were for the rear sparkplugs were just a little too short to fit into the wire looms. I will have to find another way to keep them off of the valve covers.
Willie
Old Oct 4, 2007 | 06:24 AM
  #25
jwfuller's Avatar
That's my issue right now also willie. A couple of the wires could be a tad bit longer. The wires all the way from the tip to the end stay really hot on mine during operation anyway, so I guess the wires aremade for it.
Old Oct 4, 2007 | 07:17 AM
  #26
S4poor's Avatar
ORIGINAL: okdiscoguy
Can you copy the URL and paste it here for the 8mmwires (80242)forthe Disco II. I do not see them for the $68 anywhere?
Thank you much!
Old Oct 4, 2007 | 08:15 AM
  #27
03springer's Avatar
Its on the very first thread. www.apexperformance.net
Old Oct 4, 2007 | 12:34 PM
  #28
S4poor's Avatar
ORIGINAL: 03springer
I know that, I am asking for the actual URL for the part number 80142, I can't find it anywhere on the site. The only one I can find is for the D1.
TIA-
Old Oct 4, 2007 | 01:11 PM
  #29
okdiscoguy's Avatar
http://www.apexperformance.net/cartg...156&cid=10
This is for the D1. It is the direct link. It lists 3 part numbers in order of the drop down menu.
The Wires for a D2 are $81.64
Old Oct 4, 2007 | 01:34 PM
  #30
03springer's Avatar
I`ll tell you what happened. Since I started this thread about the wires, the price has gone up!! They were 68.99 for the 4.0 99-04 Still cheaper than other sites. They are now 82.99 for the 8mm ones. www.apexperformance.net/cartgenie/prodInfo.asp?pid=1155&cid=10
