Main Belt Replacement - Do-able of a Driveway
So our 19 year old Disco II carried us all the way from Houston to Aspen CO and back, coping with sheet ice, 70 mph blizzards, 4 °F temperatures, 13,000 foot passes, etc. The heater wasn't working (!) but we managed. But the old girl finally said enough is enough on the way home and stranded us last night on the wrong side of Texas when the compressor froze up and the engine wouldn't restart.
So I'm going to replace the A/C compressor itself entirely (the A/C wasn't working anyway). That is easy enough as it sits right on top the engine.
While I'm at it I need to replace the main serpentine belt.
Questions:
Q1 - Is a belt change do-able on the driveway without special tools?
Q2 - Am I right in thinking the belt also drives the camshafts and if so I presume I need to be careful to mark the crank and camshaft positions before I remove the belt? Any other precautions or steps?
Q3 - Where is the tensioner and can I back it off to slip the old belt off / the new one on, using say a socket and a pry bar or is something else involved.
Q4 - What type of refrigerant do I need to use? I can buy a vacuum pump to purge / suck all the old refrigerant and air out before refilling.
Thanks.
2001 4.0 V8 with secondary air.
Questions:
Thanks.
Yep, The Belt is real easy to do, have a look.....
> https://www.roverparts.com/resources...e-discovery-2/
I'll be doing the work myself.
Don't take off the fan. I could replace the belt blind drunk, in the dark, with my wife bitching at me. Use 2 wrenches. The box end of a 15 ( I think) on the tensioner. Use a bigger wrench as a cheater and hook it into the open groove at the top. Pry it back and pop the belt on.
Sixpack577 (12-03-2019)
