Main compressor pulley bolt
Is this bolt critical?
Bolt retains AC clutch to compressor shaft and shims for clutch adjustment.
Micko (07-25-2016)
Yes critical and should have caused some problem by now It appears to have been missing for some time and clutch may be rusted so badly to splined shaft it's allowing AC to still work. Once/when bond breaks loose if issue not addressed you'll likely be wishing it had.
would driving with the AC off be safer?
If it's worked so far, it's got to be stuck on there pretty good. The only thing I would worry about is the clutch hub falling into the fan or something like that. Turning it on pulls the hub towards the compressor. But then it kicks on and off as it runs. Maybe just use it and find a bolt as soon as you can.
austinlandroverbill
02-27-2016 02:03 PM
