Main and Rod Bearing Choices/Sources?
Old Jul 10, 2012 | 10:51 AM
ChrisDiscoii's Avatar
Question Main and Rod Bearing Choices/Sources?
Hello all, Great Forum!
I am in the process of replacing my rod and main bearings. (with engine in truck per the sticky) Long story how I got here but short version as follows...My truck started suffering with low oil pressure and ticking (sounds valve train related to me) when hot.
I searched the forum to gain as much info and followed the many great suggestions. I installed a Cyberdyne oil gauge then tried the large filter with Rotella 15/40 but was unable to improve oil pressure readings.
(17 idle cold, 35 @2000rpm cold, less then 7 idle hot, 23 @2000rpm hot)
Decided to change out oil pump gears and did find the outer ring cracked. Since I have the lower end open I decided to change rod and main bearings too. Going to go with standard dimension bearings. AB has both sets for about $80 bucks. RovahFarm has them for about $35 bucks. Anyone have any cons for going with the less expensive ones? Both are listed as STC4299 (main) and STC1426 (rod) Thanks in advance for any insights... Oh and btw do I need to change out the Dowty Washers on the side bolts?
Old Jul 10, 2012 | 03:02 PM
Go to , D&D Fabrications: Engineering & Fabrication Services for the best supply of parts.
Old Jul 10, 2012 | 06:14 PM
Thanks Mike, I will check them out.
Grlica
May 1, 2013 06:13 PM
gearoutfitter
Oct 21, 2012 07:28 PM
atancreti
Sep 18, 2011 09:26 AM
0304Disco
Jun 14, 2011 09:51 AM
jck09
May 7, 2011 05:04 PM
