Maintenance question
Old Dec 20, 2020 | 01:31 PM
RavenMocker's Avatar
Default Maintenance question
I’ve a 2000 Disco 2 with 152K milieus and own the iLAND diagnostic. I bought it when it first came out and had issues with using my iPhone. Since then updates and using an Android Tablet it seems to work well.
Now to the questions at hand. I have some issues with the Evap positive pressure test system. I’m in the process of smoke testing the system and will make the needed repairs of which I’ve already bought parts. I replaced the gas cap already. Anyway it’s not an issue as I will find the leak first then the repair as well as lines and other parts. But first I must find the leak.
I also had a few spark plug wires defective so a new NGK set has been ordered. My plugs are all burning well. I’ve bought and replacing the O2 sensors, coil packs, some vacuum lines, and a few other items. I’m going to relocate the coil pack. Which brings me to the question at hand.
I installed a new water pump last year with all new hoses, expansion bottle (and cap), thermostat housing, and converted over to HOAT coolant. My radiator fan is now electrical with thermostat. With all the things I’m replacing I thought maybe I should go ahead and do head gaskets. I don’t have the sleeve slippage. So I’m not sure I want to push my luck and wake the sleeping giant. That my question. I only added this other information to show the work I’m currently doing and some of the reasons why.
Old Dec 20, 2020 | 02:04 PM
Richard Gallant's Avatar
Why do you want to do the head gaskets,if there are no issues leave them be. The theory would be that by doing them you forestall a failure but you are opening a can of worms. i fryou engine is running well and cool leave it be
Old Dec 20, 2020 | 02:11 PM
yes I agree but I wanted to ask what others thought as to is I was just being paranoid about changing them.
Old Dec 20, 2020 | 02:35 PM
JUKE179r's Avatar
I’m all about preventative maintenance especially on a 20 year truck with possibly 20 year old parts (gaskets/seals/hoses) that will eventually fail.
Become “one” with your truck and just do it to give your Disco another 20 years of life.
Old Dec 20, 2020 | 02:45 PM
I’m torn between doing the head gaskets and fearing the worst by doing so.
Old Dec 20, 2020 | 02:54 PM
Best4x4's Avatar
HG job on a LR V8 is not hard. It just has to be done properly and it should last you a good bit as long as you keep your LR V8 happy and cool.
Old Dec 20, 2020 | 03:59 PM
for the Disco 2 who makes the best head gasket set? I’ve owned a number of 4WD’s over the years and it seems there is a preference over others depending on the vehicle.
Old Dec 20, 2020 | 04:24 PM
Best4x4's Avatar
Brand hasn't been an issue for me HG wise. Lucky8 kit is about the best deal out there vs say victor reinz kits which tend to be much more. Or grab a kit from Rovers North/Atlantic British.
Old Dec 20, 2020 | 05:25 PM
If you go this route have your heads checked and trued, if you are looking for ARP studs let me know I am pulling from a 4.6 only a few months old.
Old Dec 20, 2020 | 05:33 PM
Extinct's Avatar
You should sign up for mycarfax.com (free) and look at the service history. Very low probability at 152k that your truck has the original head gaskets. If they have already been changed they should be good for another 100k miles, particularly since you have changed the rest of the cooling system. You can also lay under the truck and look up at the engine, if the heads are clean and the block is oily, they have likely been changed. Third option, there is a small spot where you can actually see the headgaskets from above, if you can take a high resolution photo and post it I can tell you if they are OEM LR or previously replaced.
Either way I would not change the HG until needed.
