Major hesitation on highway
My 04 disco, which I had for about 2 weeks now developed major hesitation, when I take my foot of the accelerator at highway speed. Gi ing gas there is no hesitation only when I let the gas pedal go. Sofar I have done the induction cleaning, engine flush with gunk, power steering fluid flash and I have been on the second tank of premium 93 octan gas. The indu tion was done around 50-75 miles ago. The PSP still needs to be replaced but it didn't arrive yet.any idea what might be causing the hesitatiin?
How do I clean MAF and IACV
I know now where MAF and IACV are located, Rav's manual says to discard the O-ring and fit new O-ring, obviously I don't have a new O-ring, is this necessory? and when I was cleaning the throttle body, I had to releas the ducts and only thing that I saw, where the MAF is, was a plastic mesh. So how do I clean this, I don't want to damage anything and how do I clean IACV.
I just paid around $20 for only 5 O-rings for power steering pump and gear box (couldn't believe it but no way around it, since some of the O-ring's were not available any where else). I wish I knew about the MAF O-ring, the dealer is > 20 miles away.
It feels like when you push a manual car to start it, car is in first gear, your foot on the clutch, when you have some speed you let the clutch go and the car hesitates and than starts.
Now in my case this happens, when I let the gas pedal, especially when I first take my foot off it or even want to slow down. No hesitation what so ever, when I give gas. My brother is also some what mechanically inclined and he said that I might have vacuum/air leak, that when the throttle is closed, the fuel and air mixture mix is not the right one. When i did the induction, I had to take off the vacuum line, which was fitting very thight and now it is not as tight, but I don't think it is so loose that it is causing a leak. I saw on YouTube how to clean the MAF and IACV, basically just spray it with carborator cleaner, I hope this is right?
I did not clean the MAF, just the throttle body as described in the induction cleaning. I will get a code reader, to see what the codes are.
11 codes
Just some backround first.
Check engine light first came on after power washing the engine to check for leaks, it went away by itself after around a day. The Service engine soon light came on again after induction and cleaning the throttle body, it did not go away this time. I had to power wash the underside and also the engine compartment one more time and after this was done the check engine light was flashing for few minutes and than it stayed on. Today it turned of but than it came back.
I got the code reader and got 11 codes in this order
P1300, P0308, P1129, P0300, P0301, P0302, P0304, P0303, P1412, P1415 and P0152. I cleared all codes and turned off the engine light.
Could all of these be related to power wash or is there something else wrong?
Thanks
Thanks
